supercharger fuel pressure #65597
05/29/08 09:33 AM
05/29/08 09:33 AM
Colorado
hemiluver Offline OP
Colorado
Guys,
What kind of fuel pressure should I have a full throttle in 4th gear going thru the traps? The set-up? 440 Landy/B&M 174 supercharger,2 650 cfm edelbrocks,120gph edelbrock electric fuel pump,4:30 end.I notice some guys talking about there cars running out of fuel,I have felt no leaning at all,it pulls hard all the way,perhaps due to it being blown over naturally aspirated?By the way I'm at an alt of 5750ft. Thanks Legends!!-Gary
Re: supercharger fuel pressure [Re: hemiluver] #65598
05/29/08 11:54 AM
05/29/08 11:54 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If you were lean you'd know it because you'd be out a cylinder or 2. I think the rule is 6+lbs of boost??? I ran a centrif S/C unit and I had to pressurize the fuel pump.
Re: supercharger fuel pressure [Re: Mr.Yuck] #65599
05/29/08 12:04 PM
05/29/08 12:04 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
Since this is a roots blower with a draw through setup, no need to add pressure to the fuel supply as the boost increases.
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: supercharger fuel pressure [Re: hemiluver] #65600
05/29/08 12:54 PM
05/29/08 12:54 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Using Carter-brock carbs in a draw through application, you should be seeing between 4 and 5 psi at all times.
- Stu Harmon
Re: supercharger fuel pressure [Re: hemiluver] #65601
06/04/08 09:41 PM
06/04/08 09:41 PM
Colorado
Colorado
Thanks all! I went ahead and bought a 150 gph pump just to make sure I'm covered!-Gary
Re: supercharger fuel pressure [Re: feets] #65602
06/04/08 09:47 PM
06/04/08 09:47 PM
Colorado
Colorado
Man your cool I love your car!!-Gary
