Re: any a/c compressor with shaker pics?
[Re: magnum440]
#655919
04/01/10 07:02 PM
04/01/10 07:02 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
You can always get the kit to mount it under the alternator.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#655922
04/01/10 10:02 PM
04/01/10 10:02 PM
Posts: 260 WV.
Challenger_Nut
WV.
Who makes them and do the make a 'em for a small block?
[Re: screamindriver]
#655926
04/10/10 06:40 PM
04/10/10 06:40 PM
Posts: 348 texas
magnum440
texas
looks good screamer if i was using after market condensor id go that route,,,but im using bone stock a/c set up so discharge line is on drivers side...im still waitin for a/c 45 degree fittings to come in,,,im kinda mockin up shaker and it doesnt sit flat,,, its leanin down on alittle drivers side,,, did u have to bend the carb plate ,,,or r u using the feet ,,,and if so how do they mount,anybody?,,,,thanks in advance
