O2 sensor question #655640
03/30/10 08:40 AM
03/30/10 08:40 AM
Just South of The Motor City
limechallenger Offline OP
The O2 sensor on my 2002 Sebring coupe just turned my check engine light on,so I'm wondering if they are repairable or do I have to replace it? I was thinking I may be able to pull it out clean it up and go! What do you guys know about this?
Thanks!
70 T/A Challenger 78 Aspen R/T 87 Indy 500 Dakota
Re: O2 sensor question [Re: limechallenger] #655641
03/30/10 08:57 AM
03/30/10 08:57 AM
PA
Moparzrule Offline
Moparzrule  Offline
PA
Change it. They are meant to be changed like spark plugs. How many miles are on it? I don't know of a chemical that won't hurt the O2 if you try and clean it. Best thing you could try is to heat it with a propane torch to bake off the carbon. How would you get to the inside tip to clean it?
My
Own
Personal
Adrenaline
Rush
Re: O2 sensor question [Re: Moparzrule] #655642
03/30/10 09:12 AM
03/30/10 09:12 AM
92,000 miles Don't know what I would use to clean I was just asking to see if I could save a few bucks! Thanks!
Re: O2 sensor question [Re: limechallenger] #655643
03/30/10 09:19 AM
03/30/10 09:19 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Thanks!
Usually what happens is the heater shorts out inside the sensor. No amount of cleaner will fix that.
Re: O2 sensor question [Re: Todd] #655644
03/30/10 09:23 AM
03/30/10 09:23 AM
PA
Moparzrule Offline
Moparzrule  Offline
PA
I'm on my second on my Neon. The first was taken out by a dead deer I ran over then I think the deep snow took out the second fits all one I had to splice in. I recommend the exact fit ones vs the spliced in ones.
My
Own
Personal
Adrenaline
Rush
Re: O2 sensor question [Re: Moparzrule] #655645
03/30/10 04:41 PM
03/30/10 04:41 PM
NJ
rth Offline
rth  Offline
NJ
just replaced frt 2 on my 3.0 stratus. heater was no good put light on.also vote for exact fit,splice type pita.got from rock auto,best price.
Re: O2 sensor question [Re: limechallenger] #655646
03/31/10 11:30 PM
03/31/10 11:30 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Thanks!
Yes, it can be cleaned. Soak it in oven cleaner for an hour. Flush it with water and blow it out.
Worked for me on my pre-cat and post-cat sensors on an '01 Ram. Let me know if it works for you.
Mo' Farts
Moderated by "tbagger".
