Torqueflite question #655565
03/30/10 02:52 AM
03/30/10 02:52 AM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
One for the trans guys - Does the "front" band on the TF trans govern the 1-2 or 2-3 change?
Cheers
MM
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Torqueflite question [Re: Moparmal] #655566
03/30/10 02:59 AM
03/30/10 02:59 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Both... It needs to apply for 2nd gear & it needs to release for 3rd gear...
Re: Torqueflite question [Re: 1_WILD_RT] #655567
03/30/10 03:03 AM
03/30/10 03:03 AM
Moparmal Offline OP
Moparmal  Offline OP
Fair point on the "release" - I should have asked when it "applies" -
So it applies on the 1-2 change?
Re: Torqueflite question [Re: Moparmal] #655568
03/30/10 03:07 AM
03/30/10 03:07 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yes.. The reason I mention release is Torqueflights can have what is called a "shift overlap" where the front clutch applys quicker than the front band releases...
Re: Torqueflite question [Re: 1_WILD_RT] #655569
03/30/10 03:15 AM
03/30/10 03:15 AM
Moparmal Offline OP
Moparmal  Offline OP
Thanks again - Reason I ask is that I've just fitted the 390 stroker with a 248 duration .520 lift cam - and the 2-3 change started to "flare".
Ive fitted steel planetaries and it has a good converter (904) a while back but the band started to slip whe we put the new engine in last week.
I'v had it serviced now - and its holding OK - but someone told me that the SB strokers are hard on the "front" band - so I wanted to make sure I know what to look for and monitor the changes and make sure nothing weird happens.
I'll watch the 1-2 change like a hawk and one day I'll have to read up on how TF actually works
Re: Torqueflite question [Re: Moparmal] #655570
03/30/10 10:17 AM
03/30/10 10:17 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Most likely the band adjustment was way too loose.
