340 / flat spot off idle eddy carb
#655447
03/29/10 09:47 PM
03/29/10 09:47 PM
Posts: 4,503 NJ
440challenger
NJ
having a problem tuning this 340 . Its got 360 j heads,10-5-1 pistons,484 cam ,eddy 600 with air gap intake. Im a Big block guy, where should the timing be around on a 340? put in as much initial as i can? Has a huge flat spot off the bottom. Eddy 600's known to have that?
Re: 340 / flat spot off idle eddy carb
[Re: 440challenger]
#655452
03/29/10 10:05 PM
03/29/10 10:05 PM
RapidRobert
I have an eddy 600 (1406 I believe (elec choke) and I chased a hesitation. It's a main metering lean problem. Idle the car for a minute to fill the bowls then pull the top and (car level) the fuel level should be at the slot in the float baffles (on each side). I had to richen my jets to eliminate a hesitation and the AP had an immediate and lengthy squirt so I knew that wasn't it. Runs excellent now. Do set the timing 1st ~12-20 depending on what the cam/eng wants (vac gauge method works well) then shorten the slots for 35 total (initial and total set w vac adv disconnected if a VA is used)
[Re: 440challenger]
#655453
03/29/10 11:05 PM
03/29/10 11:05 PM
Posts: 353 Chesterfield, MIch
Cuda67
super street
super street
Chesterfield, MIch
Does your Eddy have vaccumn or mechanical secondaries. I'm betting you have the mechincal and you need the vaccumn. I had the Eddy on my 383 (mechanical). I tried for a few years everything. Changed everything. Finally bought a Holley with the vac secondaries, bolted it on and presto the prob completly disappered. Now I need a lot better tire. Car is an automatic and smokes the tires.
[Re: Cuda67]
#655454
03/30/10 01:25 PM
03/30/10 01:25 PM
Posts: 5,270 Missouri
MY340
Missouri
Bump up the timing to around 18-20 intial first and then tune the carb from there. This will help or cure the flat spot plus idle quality as you may not be on the idle circuit if you've got the idle speed screwed in alot. This may be why the idle mix screws don't respond. Middle or top hole for the accel pump depending on what your motor wants for intial squirt. My 360 with a 750 Eddy likes the middle hole. You may need lighter springs if your vacuum is low and you hear a fluttering/buzzing sound plus the carb will load up & die if idling for any length of time. Pretty soon Swingin 72 will respond with "get rid of the Eddy and buy a Holley!"
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: 69Cuda340S]
#655456
03/31/10 07:37 PM
03/31/10 07:37 PM
Posts: 4,503 NJ
440challenger
NJ
Ok well i tried checking the timing and my good dial back matco light will not work on this car for some reason. I thought it was the msd wire,so i put a stock plug wire on still no good. I advanced the timing by highest engine rpm then checked my vaccum,only about 5. turned the a/f screws all the way IN and my vaccum is no around 12 and the dead spot is gone and engine runs 100% better. My question now, any idea why my timing lights not working ? The car has a msd coil with mallory elec distributor.
How do i get more engine vaccum without running the a/f screws all the way in. Shouldnt they be about 1 1/2 to 2 turns out?
THANKS for the help!
[Re: 440challenger]
#655457
03/31/10 08:42 PM
03/31/10 08:42 PM
RapidRobert
I'd borrow a light & (1) see what your initial is (2) see how far open the blades are open in the throttle bore (Start by turning the timing SPEED screw CCW till it's free and count the turns so you can return it to that spot). Do you have an MSD box which can play havoc w a dialback? What is the idle speed now? Is all good ex for the # of mixture needles turns does not appear anywhere near correct? For sure see where the timing is at & shorten the slots accordingly (if need be). Holler back w any new developments
