Resticting evac breather lines
#655407
03/29/10 09:28 PM
03/29/10 09:28 PM
Posts: 1,200 UK
602heavy
UK
Pulling a hell of a lot of oil/vapour out of breathers & into exhausts (full exhaust) , got the covers baffled as good as i'm gonna get , was thinking of restricting the breather tubes? , can put a valve in line from breather to evacs which will enable me to play with the restriction , anyone had to do this?
TIA
Re: Resticting evac breather lines
[Re: 602heavy]
#655410
03/30/10 02:33 AM
03/30/10 02:33 AM
Posts: 176 Rome, GA
GTXX
Rome, GA
I know it's not the problem, but when you blocked off the check valves they overheated because no air was flowing through them. remove the valves and install a 1/2 NPT pipe cap if you need to run without check valves again.
'71 GTX w/Air Grabber, Super Trak Pak, Spoiler Pkg. been apart for 22 years, thinking it's time to do something about that....
[Re: GTXX]
#655411
03/30/10 04:33 AM
03/30/10 04:33 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Either this or the exhaust has too much back pressure and it burnt the valves... for every inch HG of back pressure on the exhaust it will reduce the engine vac by the same amount.... the evac has about 5"HG max. You could put a catch bottle in line on the evac to collect the oil or put a better baffle in the valve covers
[Re: MR_P_BODY]
#655414
03/30/10 09:35 AM
03/30/10 09:35 AM
Posts: 8,165 Left Coast
BobR
Left Coast
I think it was last month some one posted a pic of home made breather caps that were around 3.5" tall, kinda like a catch bottle on the valve covers,
I sorta think he has the nipple in the collector mounted wrong... it very well could be pressurizing the crank case and pushing oil up past the rings and blowing it out the exhaust..... just a guess because he doesnt have blowby with the hoses off OR he just needs a better baffle.... like I said ... just a guess OR his exhaust has more back pressure than he thinks
I agree. I think that there is VERY LITTLE chance his problem is what he thinks it is.
[Re: MR_P_BODY]
#655415
03/30/10 01:58 PM
03/30/10 01:58 PM
Posts: 1,200 UK
602heavy
UK
The baffles are sealed on all four sides with a slot cut @ the side tight to side of valve cover , the oil would have a hell of a job finding it's way into the baffle with splash , the evacs pull vac from idle to full throttle , @ idle i can pick a box of ciggarettes up with the breather , when ran with no evac just breathers the filter/baffles are clean as a whistle , no fouling plugs either , just gotta find a way to make this work , this is a 605" with 2 1/8th primaries , i remember reading someone on here had to restrict the breather into valve cover , another guy also had issues running ex evacs with full exhaust , just need to play around till the problem gets sorted out.
[Re: 602heavy]
#655416
03/30/10 03:22 PM
03/30/10 03:22 PM
BobR
Left Coast
We pull 17 pounds with a vacuum pump and end up with very little oil in the puke tank. Restricting the vacuum sounds counterproductive to me especially since the header evacs do very little anyway. Unless you have racepak data or a vac gauge somewhere in your crankcase you really don't know what's going on. I think that it's far more likely the scenario that Raff suggested than the evac system is pulling oil out of the baffled breathers.
Post deleted by Defbob
[Re: BobR]
#655417
03/30/10 03:41 PM
03/30/10 03:41 PM
#655418
03/30/10 04:01 PM
03/30/10 04:01 PM
BobR
Left Coast
he's blowing exhaust into the motor and somehow it's pushing oil out
That's exactly what Raff said and exactly what I think is going on.
[Re: MR_P_BODY]
#655420
03/30/10 04:18 PM
03/30/10 04:18 PM
#655421
04/02/10 04:07 PM
04/02/10 04:07 PM
Posts: 1,200 UK
602heavy
UK
Had a leak on the valley plate , seems the air leak had a path to breathers that carried oil mist , smoke seems to of disapeared from tail pipes , just took a bit of time for this to work. Seems all is ok regards ring seal although the rings are gapped for the spray. Thanks.
[Re: 602heavy]
#655422
04/02/10 06:24 PM
04/02/10 06:24 PM
[Re: 602heavy]
#655423
04/02/10 08:59 PM
04/02/10 08:59 PM
BobR
Left Coast
Thanks.
Are you sure that oil wasn't leaking from the lifter valley into an intake port? This is fairly common.
#655424
04/02/10 09:26 PM
04/02/10 09:26 PM
Posts: 1,200 UK
602heavy
UK
Thanks.
no sorry but that wssn't it.. if you had a leak there then there would be no vacuum or suction at the evac line thus no oil getting pulled out
Guys , seems you're making something out of nothing , it's a well known fact evacs with full ex will pull oil out of engine , the original question was feedback on guys that run evacs with full exhaust & how they overcome pulling too much oil mist , seems the leak was smaller than what the evacs pull , still had vacumme but was pulling oil mist due to the air leak/stream being sucked into valve breathers , all is good & have no issues with blowby/ring seal , sometimes we tend to delve too deep for a simple solution.
Thanks again.
[Re: BobR]
#655425
04/02/10 09:30 PM
04/02/10 09:30 PM
Posts: 1,200 UK
602heavy
UK
Thanks.
This engine uses a valley tray as oposed to a pan , the only way it can suck oil is if the hold down bolts on Jessel stands are not sealed.
