71 413 rings
#655394
03/29/10 09:25 PM
03/29/10 09:25 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
so... i have a interesting question. i have a 71 413-HT. i need to pull a couple of pistons out to clean out the bore. my only problem is the rings. i dont want to re-ring the whole engine, just the two pistons i need to remove. my brother has rings that are the right diamater, the only problem is that they are about 1/64th too thin. is that going to be a problem, or can i get away with using those rings? thanks for the help!!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 71 413 rings
[Re: dOrk !]
#655396
03/29/10 11:31 PM
03/29/10 11:31 PM
GTSDart340
Laveen, Arizona
these are just the stock pistons.
Re: 71 413 rings
[Re: GTSDart340]
#655398
03/30/10 09:59 AM
03/30/10 09:59 AM
RapidRobert
Gap or side clearance? If side clearance a 5/64" (.078") std width Mopar ring. 1/64 smaller would make an additional 15&1/2 thou side clearance on top of the several thou there now which would be way out of spec. For a low buck deal I'd try it. It wouldn't seal as good and I'm sure the up/down play would shorten the life of the rings/piston
Re: 71 413 rings
[Re: RapidRobert]
#655399
03/31/10 10:53 PM
03/31/10 10:53 PM
GTSDart340
Laveen, Arizona
i dont have the engine apart yet.. i dont want to tear it apart unless i know if these rings will work. im trying to low budget this engine, and then if it doesnt work i will rebuild it at a later date. im eventually going to turbo it (after it gets rebuilt of course!), but cant afford to buy a complete set of rings now. the clearance im talking about is side clearance. as in how thick the ring is. thanks!!
Re: 71 413 rings
[Re: GTSDart340]
#655400
03/31/10 10:57 PM
03/31/10 10:57 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
But BUYING single rings(in many cases) will cost you MORE than buying a set !!
And IF there is a TON of ring-groove-slop .. the motor will NEVER seal-up.
