Convert your existant Mopat alt into ONE WIRE ALT ? #654968
03/29/10 06:09 PM
03/29/10 06:09 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
HERE YOU HAVE
http://store.alternatorparts.com/partnod7018.aspx
no more than a mount on regulator, with wirings attached directly to alt. The regulator "exciter" or SWITCH ON is the stator lead, no need for ign key signal
forget about get a complete "one wire alt" in $120 or more if you have a good working order alt ( unless you want a 100 amps or more alt coming also with this mount on regulator )
VALID ONLY FOR DUAL FIELD/PRONG, not single ( at least without mods... it can be done )
Re: Convert your existant Mopat alt into ONE WIRE ALT ? [Re: NachoRT74] #654969
03/29/10 09:35 PM
03/29/10 09:35 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
Looks cool
Re: Convert your existant Mopat alt into ONE WIRE ALT ? [Re: Alikazam] #654970
03/29/10 11:34 PM
03/29/10 11:34 PM
Valencia, España
Valencia, España
is the same stuff you get on powermaster one wire alts... a "regular" alt with this regulator mounted on it
