Re: pinion offset Q
[Re: sshemi]
#654828
03/30/10 12:55 PM
03/30/10 12:55 PM
Posts: 415 Indiana
Pentastar440
Indiana
If your present rear is centered and you are using stock motor mounts then the new rear with offset will line up better than the one you have now. I think that you will be fine. The whole tunnel in your car is offset to the passenger side.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: pinion offset Q
[Re: sshemi]
#654829
03/30/10 01:18 PM
03/30/10 01:18 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
is this a stock chassis car or tube chassis car?
