Re: do you balance your rear slicks 14x32
[Re: BobR]
#654794
03/29/10 01:46 PM
03/29/10 01:46 PM
Posts: 1,647 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I balance mine, when first installed ! Also rebalance them when I am rotating them, about every 50 passes. It is nice when you don't have a Vibration....
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Challenger 1]
#654798
03/29/10 02:24 PM
03/29/10 02:24 PM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
look at the back tires on some cars in the burnout box and you'll change your minds about not balancing your slicks ![](/ubbthreads/images/graemlins/Twocents.gif) I've seen some that look like a basketball bouncing
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
[Re: MegaDart]
#654801
03/29/10 02:59 PM
03/29/10 02:59 PM
Posts: 7 AB Canada
Demon Guy
AB Canada
I would balance them if you can, Static/balance out the heavy spot. Ever wonder why some slicks in the burn out box are smooth and some bounce like StripeHog said. I have seen unbalance slicks show cords on one side and lots of wear indicator showing on opposite side. I have also driven a buddys car were it vibrated so bad I thought it was coming apart, balanced the slicks and smooth as silk.
71 Demon 451 SR All Motor
Chassis car 2475 w/driver
Best ET 9.08 @ 150.05, 4787 Corrected Alt
[Re: hemi-itis]
#654807
03/29/10 08:43 PM
03/29/10 08:43 PM
Posts: 753 San Diego, CA
brktracr
super street
super street
San Diego, CA
I had a set that were out of balance, it would vibrate hard enough to shake my eye balls. Always bubble balance them after they get mounted.
1.298 60 ft
6.001 1/8 mile
114 mph
9.52 1/4 mile
140.87 mph
@ 3110 lbs
