Re: 66-67 B Body gas tank "question mark" bolt
[Re: dpatt67]
#65466
05/29/08 01:28 AM
05/29/08 01:28 AM
Posts: 5,161 CT
GTX MATT
CT
Hey Pat, ive got to take a gas tank out of a '67 im parting in the next week or two. If you want and the bolt is usable I can send it to you if you cover shipping.
Matt
[Re: bobby66]
#65470
05/29/08 09:46 AM
05/29/08 09:46 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Mine came from Year One. '66 Charger.
but is it the RIGHT one ?
the correct bolt is not currently available , i was not comfortable with using a later j bolt in a 67 i worked on .
matt if he doesn't take you up on it i'll take that bolt .
if you aren't going to use the strap in the car cut it and let me get the nut off the bolt .
[Re: dpatt67]
#65471
05/29/08 02:43 PM
05/29/08 02:43 PM
Posts: 238 Okla
dpatt67
Okla
Matt: If the bolt is decent i sure would take you up on the offer. Thanks, and let me know how much to 74055. I find it hard to believe that they reproduce the tank, sending unit, strap, hoses, etc. for these cars and nobody makes the bolt to put it all in with.
66 Coronet 67 Satellite 15 Ram 3500 12 Challenger R/T
[Re: CR8CRSHR]
#65473
05/29/08 05:49 PM
05/29/08 05:49 PM
JohnRR
U.S.S.A.
J Bolts are out there if you search for pretty much all years and models. But really does it matter as no one will ever see it if you improvise with something else. Unless of course you are going for a concourse restoration...
no it does matter and its not because of a correct restoration issue , its a keeping the gas tank off the ground issue
[Re: TC@HP2]
#65477
05/30/08 07:50 AM
05/30/08 07:50 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
How different are they from the 68+ ones? I have this one for $25.
Night and day.... This is the one in question
