A Body Drum Brakes 4 1/2 bolt pattern?
#654004
03/28/10 06:57 PM
03/28/10 06:57 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
Is there such a thing as a large bolt pattern A Body FRONT brake drum? What would they have in 73 or 74? Can a front drum brake set-up from a E Body work? A customer wants to up-grade to Large Bolt Pattern on his A Body to accommodate his rim choice, but we were both wondering if he can retain the drum brakes all around... I know it would be way better with front disc brakes but that's not the answer I'm looking for...Thank you...
CHECK OUT MY NEW WEB SITE !
Re: A Body Drum Brakes 4 1/2 bolt pattern?
[Re: anlauto]
#654005
03/28/10 07:25 PM
03/28/10 07:25 PM
Posts: 1,169 MI
68shifter
MI
I took off my entire assembly and sent it into strange and they re-drilled and checked balance for the larger bolt pattern. I think labor was like $75, shipping more obviously, and had them back in a week. I'm sure Moser and all the other ones can do it too. Worked well and have had 0 problems in 6-7 years drag racing it.
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: anlauto]
#654006
03/28/10 10:28 PM
03/28/10 10:28 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
A body with front drums was sbp until the end of production. You can use any '72-earlier B drum assembly or any E body drum brake/spindle assembly as long as you use '73-up A-body upper control arms since they have the big ball joints that you will need.
[Re: 446acuda]
#654010
03/28/10 11:23 PM
03/28/10 11:23 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
use B body stuff if you want BBP drums on an A body.
[Re: DusterKrazy]
#654012
03/29/10 01:39 AM
03/29/10 01:39 AM
Posts: 416 Franklin Co. Illinois
runinonmt
Check bearing sizes. I believe the B-body spindles are larger. Maybe use spindles too, or a bushing on the A-body spindle. I'll eventually need to do the same. Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
[Re: anlauto]
#654014
03/29/10 07:44 AM
03/29/10 07:44 AM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
I have been told that there are some drum/hub assemlies from some AMC vehicles with 4 1/2 inch pattern drums, that will go directly on the A body mopar spindle. It was a pacer, or Gremlin I think. Maybe someone else here knows, or you may investigate.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: DusterKrazy]
#654015
03/29/10 09:18 AM
03/29/10 09:18 AM
446acuda
Charlotte, NC
So on my '76 Scamp, I could retain my upper and lower control arms and then just change the spindles to get disc brakes?
yes
