Dipstick Tube #653576
03/28/10 02:38 PM
03/28/10 02:38 PM
Westchester, NY
JM67RT Offline OP
JM67RT  Offline OP
Westchester, NY
When Iwas putting the headers into my 65 383, I had to move the dipstick tube out of the way and it came out (or so I thought). Looks loke it might have broke off clean with the block? It's not sliding back into the hole. Am I totally screwed? Are any of the adjustable (Mancini, Lokar) tapered so they might fit into the hole?
Re: Dipstick Tube [Re: JM67RT] #653577
03/28/10 02:40 PM
03/28/10 02:40 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
If it broke off you need to get the peice out of block.
Re: Dipstick Tube [Re: Dougsmopars] #653578
03/28/10 02:48 PM
03/28/10 02:48 PM
Long Island NY
yellow sixpack Offline
Long Island NY
That tube is pushed into the block. You need to get someting in there and pull it out. Might want to cut a slight line in the broke part of the tube and bend it out so maybe you can get a grip on it.
If you can't be smart.....don't be stupid!
Re: Dipstick Tube [Re: yellow sixpack] #653579
03/28/10 03:38 PM
03/28/10 03:38 PM
Westchester, NY
JM67RT Offline OP
JM67RT  Offline OP
Westchester, NY
Any idea how far the tube goes into the block?
Re: Dipstick Tube [Re: JM67RT] #653580
03/28/10 03:39 PM
03/28/10 03:39 PM
Kirkland, Washington
Pacnorthcuda Offline
About an inch. Try to insert somethig shaped like a nail-head against the end (ridge) and pull
Re: Dipstick Tube [Re: JM67RT] #653581
03/28/10 03:44 PM
03/28/10 03:44 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
4 inches of dipstick and then there should be a ridged bit an inch up the tube. Is that still there?
Re: Dipstick Tube [Re: GwaiiEagle] #653582
03/28/10 05:35 PM
03/28/10 05:35 PM
Retired now in Tennessee
Chi_Town_Runner Offline
Try a machine screw just slightly larger than the inside diameter of the remaining dip stick tube.
Then thread the screw into the remaining tube in the block and then try pulling the tube and screw out.
Hope this helps.
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
