Best throttle cable bracket for magnum conversion? #653322
03/28/10 09:09 AM
03/28/10 09:09 AM
Milwaukee, WI
Prince_Valiant Offline OP
Milwaukee, WI
Hey guys, I'm looking for input for the best throttle bracket for a magnum converted truck I've got...it has an automatic transmission using a cable instead of a kickdown linkage.
Further info: Holley carb, edlebrock performer air-gap carb.
tia,
chris
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: Best throttle cable bracket for magnum conversion? [Re: Prince_Valiant] #653323
03/28/10 11:41 AM
03/28/10 11:41 AM
AndyF Offline
AndyF  Offline
One of these Magnum throttle brackets from Mancini Racing might work. They have a tab on them to hold a Lokar cable kickdown. Not sure if they'll work with a stock cable kickdown setup or not.
Re: Best throttle cable bracket for magnum conversion? [Re: Prince_Valiant] #653324
03/28/10 11:45 AM
03/28/10 11:45 AM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
This is the Lokar Setup. It will work really well if you run their throttle cable and kickdown cable as well. I kinda doubt it would work with any other ones though.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Best throttle cable bracket for magnum conversion? [Re: Prince_Valiant] #653325
04/13/10 07:49 AM
04/13/10 07:49 AM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
tia,
chris
Chris, the setup is the one from BPE fyi. Hopefully, this will help you.
http://bouchillonperformance.com/BPEtkdc.asp
