360 magnum using oil #653203
03/27/10 11:54 PM
03/27/10 11:54 PM
Hanceville,AL
71 R/T Offline OP
71 R/T  Offline OP
Hanceville,AL
I have a 99 darango with a 360 and it will use oil when towing with it.It has done this since nearly new,if not towing it does not use any oil but put a car on a trailer behind it and it will drink the oil.I have heard this same problem from others but was wondering if any one know's a fix for it.
Re: 360 magnum using oil [Re: 71 R/T] #653204
03/28/10 01:04 AM
03/28/10 01:04 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
A common problem for 318 and 360 Magnums is the intake manifold. There is a sheetmetal plate on the bottom side and the gasket blows out. One indicator is an occasional back fire.
Re: 360 magnum using oil [Re: 52savoy] #653205
03/28/10 01:46 AM
03/28/10 01:46 AM
Hanceville,AL
71 R/T Offline OP
71 R/T  Offline OP
Hanceville,AL
Thanks,I guess I will pull the intake and see if that's the problem.
