904 tail shaft housing same as 727?
#653112
03/27/10 10:48 PM
03/27/10 10:48 PM
Posts: 502 North Texas
1AARCUDA
North Texas
Broke my tailshaft housing on my 727, is a 904 housing the same? I have a parts car with a 904 I can pull out.
1970 AAR CUDA
1970 Super Bee 383 Auto
1969 Super Bee 383 4Spd
1968 Satellite 500 Stroker
1986 Shelby GLHS
1970 Coronet 500 383 Auto
1996 Indy Pace Truck
1998 Dakota R/T 408 Stroker
Re: 904 tail shaft housing same as 727?
[Re: 1AARCUDA]
#653113
03/27/10 10:50 PM
03/27/10 10:50 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
No, the 904 is shorter.
Any 727 one will work though. Big or small block the tail housing s are the same.
[Re: '72CudaRacer]
#653115
03/27/10 11:06 PM
03/27/10 11:06 PM
WILD BILL
BROOK PARK, OH
Tell everyone how you know, Bill
I think everyone already knows
[Re: 1AARCUDA]
#653117
03/28/10 07:18 AM
03/28/10 07:18 AM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
How and when where did it brake ? if it was in 1st gear might have taken the sprag . Might be ok if ujoint or something else caused it. Don
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: 1AARCUDA]
#653118
03/28/10 09:50 AM
03/28/10 09:50 AM
1AARCUDA
North Texas
This is my second housing to break or crack rather, I am thinking my driveshaft may be to long and when my rear winds up its shoving it into the rear of the trans, I have not had a chance to pull the driveshaft apart car is still on the trailer. I noticed a vibration after my run slowing it down and on the return lane, got it in the pits and noticed tranny fluid leaking
1970 AAR CUDA
1986 Shelby GLHS
[Re: 1AARCUDA]
#653121
03/28/10 12:05 PM
03/28/10 12:05 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
This is my second housing to brake or crack rather, I am thinking my driveshaft may be to long and when my rear winds up its shoving it into the rear of the trans, I have not had a chance to pull the driveshaft apart car is still on the trailer. I noticed a vibration after my run slowing it down and on the return line, got it in the pits and noticed tranny fluid leaking
If you have old leafsprings this could be doing it too. I knew a car that did this. The pinion angle was fine,tranny mount was fine,driveshaft was fine. Springs were weak and moving the pinion angle all over during the launch,shifts,burn-outs etc...Put a new set of springs in with the 4th tail shaft and it never broke again and never got that ugly vibration again....
[Re: 1AARCUDA]
#653122
03/28/10 01:12 PM
03/28/10 01:12 PM
1AARCUDA
North Texas
I bet its my driveshaft being to long, its the same one that was with my 904 and it has a shorter tailshaft then...
1970 AAR CUDA
1986 Shelby GLHS
[Re: 1AARCUDA]
#653124
03/28/10 01:19 PM
03/28/10 01:19 PM
WILD BILL
BROOK PARK, OH
I'm surprised you got it to fit in there
You need to find a 727 shaft you have yours cut down.
[Re: 1AARCUDA]
#653125
03/28/10 01:40 PM
03/28/10 01:40 PM
1AARCUDA
North Texas
Hmmm, then I have no clue where I got this driveshaft, I thought it was the same one that came with the 318/904 setup. But i will get a good measurement when I pull the housing off.
1970 AAR CUDA
1986 Shelby GLHS
