alternator gauge issue
#65290
05/28/08 06:18 PM
05/28/08 06:18 PM
My alternator gauge is acting strange in my 68 Charger R/T. At idle it is 0 to slightly minus, but recently it is going all the way to plus 40 when it get over 1500 rpm. Every piece of wiring in the car is new Year one harnesses. I have the solid state voltage regulator that is in the original looking 68 style caseing. Alternator has 3 connections and it has a chrome ignition box, all which are new. What do I check first? Car runs fine and starts right up after driving it.
Re: alternator gauge issue
#65291
05/28/08 10:05 PM
05/28/08 10:05 PM
Posts: 3,072 Farmland, IN
Ludington1
Farmland, IN
I'll give you a for this one... maybe the question here should be: How "should" the factory in-dash amp gauge be reading under normal driving conditions? I would say mine is: In gear, stopped, foot on brake, headlights on = Reads about -20 on the gauge In park, idling, no headlights = Reads just slightly to the "-" side Cruising at a constant speed, lights on or off = Reads maybe up to +20 on the gauge Under heavy acceleration, it will sometimes jump up above +20 but just for short temporary bursts. I'd like to hear from others about how their gauge behaves. Darren
[Re: Ludington1]
#65292
05/28/08 10:26 PM
05/28/08 10:26 PM
What an ammeter does depends on a few things:
The charge on the battery
The amount of load, like lights, heater, A/C
The RPM of the engine.
When you start a car, say in the spring, when you don't need heat or A/C, and get out on the blvd and cruise for a few miles, it should not take long for the meter to "zero" when cruising at a steady speed. At speed, say you turn on the A/C. The meter might jump a little, but it should go right back to center.
Now, here you are at the "red light." The engine is idling slowly, maybe you've got both the lights and the A/C running, so there's lots of load. The alternator cannot keep up, so the meter goes negative some amount.
If you rev the engine a little, or go through the light, the meter should charge again, for a little while, until it gets the battery "caught up."
Some good indicators of problems IN THE LONG RUN are things like wild fluctuations, dim or really bright lights, odor from the battery, or worse, damage to the cables and paint around the battery.
Of course if you let the dreaded smoke out, that's still another story.
The other problem with ammeters, is, it turns out all these late '60's and early '70's cars had a poor design, namely the wire size was marginal, the firewall connector is a problem, and the ammeter connections can get hot, loose, and fail.
Also, when you start rewireing them, you can end up with loads--like accessory lamps, or even things being re-wired--you can end up with loads on the "wrong side" of the ammeter, electrically. This will cause the ammeter to give you erroneous readings.
My problem is, I really like ammeters, but more and more, as I read the posts on these forums, I realize what a pain they've become.
#65294
05/29/08 02:51 AM
05/29/08 02:51 AM
GO to this web site and it will answer all your questions on your alter. gauge issues. And tell you how to fix them. Trust me we went throught 5 cars with this problem and corrected them all. http://www.madelectrical.com/electricaltech/amp-gauges.shtml
#65295
05/29/08 10:43 AM
05/29/08 10:43 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
that website explains good stuff, but is half wrong. They state the main splice is being moved to ouside the cab, what is totally wrong. The main splice is still INSIDE the cab and there is no way to change that, but now with that mod, power runs just by ONE wire instead the double feed from original setup.
Demands of power will be allways INSIDE THE CAB and there is no way to change that, all switches, routing etc begin inside
only true is they are saving the melting points on bulkhead and amm points, but:
1-bulkhead is saved with same mod I'm explain it and don't need to touch the bulkhead. Is not an exlusive idea. MaMopar had that double wiring on High packaged cars with ore than 60 amps... like towed packaged cars etc...
2-amm and its wires will be safe if you have balanced power source coming from alt, begining to get charge at iddle.
FIRST get worried about get charge at iddle and a good output alt, THEN, get worried about the wiring ( unles you already have damaged the wiring what if so, would it need to be saved first )
#65297
05/30/08 09:29 PM
05/30/08 09:29 PM
Posts: 308 Turneffe
BJohnson
Turneffe
Are you saying that you are using a '70 and later alternator with a '69 and earlier voltage regulator?
[Re: BJohnson]
#65298
05/31/08 02:06 AM
05/31/08 02:06 AM
RapidRobert
If it just started, (1)VR lost it's ground or(2) batt has a bad cell. or(3) corroded connections somewhere.
