No power steering after burnout #652842
03/27/10 07:31 PM
03/27/10 07:31 PM
ogletownpa
3
383'D Offline OP
383'D  Offline OP
ogletownpa
72 barraucda ,383 ,trw steering pump,factory steering box, new tight belt. My power steering works untill I do a burnout. Then It don't work for 3 miles and will come back in .and work fine. The fluid is burnt and brown.The steering box valve was completly crudded up, but thats seemed fine since last fall.I have done the pump seals , but ,does my pump need rebuilt.
Re: No power steering after burnout [Re: 383'D] #652843
03/27/10 07:43 PM
03/27/10 07:43 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Sounds like the valve is getting stuck when you bring up the RPM. Also sounds like a fluid change is in order.
Re: No power steering after burnout [Re: Dougsmopars] #652844
03/27/10 08:22 PM
03/27/10 08:22 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Pressure relief valve is opening & getting stuck... It is the valve located directly behind the fitting on the pump that the pressure hose screws into.. Remove the hose, remove the fitting, the valve is under light/moderate spring tension.. Pull it out & look for debris, burrs, anything that could cause it to stick..
Re: No power steering after burnout [Re: 1_WILD_RT] #652845
03/27/10 08:30 PM
03/27/10 08:30 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I once had one.that nearly cost me my life....while driving..made a slight turn..wheel kept going to the left..almost forcing me into on coming traffic..locked hard and wheel spun to the left..
Re: No power steering after burnout [Re: 340dart4spd ] #652846
03/27/10 08:34 PM
03/27/10 08:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
That would be the spool valve like cornet684me had cause him to have an incident today.. The relief valve won't cause that.. Just a complete loss of assist..
Re: No power steering after burnout [Re: 1_WILD_RT] #652847
03/27/10 08:37 PM
03/27/10 08:37 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Yea.. just made me think of it...nearly took my arm off....that was scary..... there is a reason they tell you not to mess with them..unless you know what you are doing...
Re: No power steering after burnout [Re: 383'D] #652848
03/28/10 03:04 AM
03/28/10 03:04 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I had intermittent loss of assist with the power steering on my 70 Charger. I added a factory police spec P/S fluid cooler from an 87 Diplomat. Before, it would sometimes feel notchy after hard driving or after several turns in hot weather. Now it always feels right.
