Milidon gear drive, BB with TCI Rattler****UPDATE*****
#652831
03/27/10 07:04 PM
03/27/10 07:04 PM
Posts: 2,051 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Anyone on here have any experience with a Milidon gear drive set up and a TCI Rattler balancer? I'm concerned with the screws on the back side of balancer hitting the idler cover on the front cover. Also I got this unit with out the alignment dowels (5/16"). Are the dowels the same size from end to end or different diameter on each end? The dowels should be a slight press fit in the block but not in the cover. Thanks for any input, Brian I'll answer my own question...****(insert 4 letter word here)NO it won't fit/work. The back of the damper hits the seal bore before it goes all the way up. The opening between the snout and the ring had too small of a diameter. I basicly wasted all day on this sum B. Going 170 miles round trip to pick it up, looking for dowel pins, cleaning & checking, only to find out it won't work with my damper. *%>$#!^#* Anyone have any idea WHICH dampers will fit it? Thanks, Brian
Re: Milidon gear drive, BB with TCI Rattler****UPDATE*****
[Re: '72CudaRacer]
#652835
03/27/10 10:58 PM
03/27/10 10:58 PM
'72CudaRacer
Mooresburg, Tn
At this point I'm thinking this sat ain't looking so good.
[Re: '72CudaRacer]
#652837
03/28/10 12:25 PM
03/28/10 12:25 PM
Thumperdart
State of confusion
When I ran the Milidon gear drive I used(and still do)use the Fluidampr..........no problems then or now.
