Milidon gear drive, BB with TCI Rattler****UPDATE***** #652831
03/27/10 07:04 PM
03/27/10 07:04 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
Anyone on here have any experience with a Milidon gear drive set up and a TCI Rattler balancer? I'm concerned with the screws on the back side of balancer hitting the idler cover on the front cover.
Also I got this unit with out the alignment dowels (5/16"). Are the dowels the same size from end to end or different diameter on each end? The dowels should be a slight press fit in the block but not in the cover.
Thanks for any input,
Brian
I'll answer my own question...****(insert 4 letter word here)NO it won't fit/work. The back of the damper hits the seal bore before it goes all the way up. The opening between the snout and the ring had too small of a diameter.
I basicly wasted all day on this sum B. Going 170 miles round trip to pick it up, looking for dowel pins, cleaning & checking, only to find out it won't work with my damper.
Anyone have any idea WHICH dampers will fit it?
Thanks, Brian
Re: Milidon gear drive, BB with TCI Rattler [Re: '72CudaRacer] #652832
03/27/10 07:11 PM
03/27/10 07:11 PM
UK
602heavy Offline
602heavy  Offline
UK
Can't help on the damper but the dowels on block are stock as are the holes in gear drive/timing cover , they are a pretty tight fit into the cover.
Re: Milidon gear drive, BB with TCI Rattler [Re: '72CudaRacer] #652833
03/27/10 07:40 PM
03/27/10 07:40 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Not to hi-jack but ...
If the timing cover has to space out from the block to accomodate a geardrive, what happens to the damper spacing? Are there spacers made to space the damper out ?
Thanks,
Here's what I'm talking about ... the plate is 1/8" thick.
Re: Milidon gear drive, BB with TCI Rattler [Re: '72CudaRacer] #652834
03/27/10 10:23 PM
03/27/10 10:23 PM
Missouri
galen Offline
galen  Offline
Missouri
My dowels were a straght 5/16. Once your gear lash is set you run your 5/16 reamer down through the hardened steel inserts in the milodon timing cover and ream the block to size. I got the info on setting gearlash on the milodon site. Cover fit very tight on the dowels when I was done but gearlash stays put. As far as TCI I am not sure, I did have to buy the longer hub for my ATI because the damper hit the cover.
Re: Milidon gear drive, BB with TCI Rattler****UPDATE***** [Re: '72CudaRacer] #652835
03/27/10 10:58 PM
03/27/10 10:58 PM
Mooresburg, Tn
Mooresburg, Tn
Brian
Thanks, Brian
At this point I'm thinking this sat ain't looking so good.
Re: Milidon gear drive, BB with TCI Rattler****UPDATE***** [Re: '72CudaRacer] #652836
03/28/10 09:25 AM
03/28/10 09:25 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
The dowels are not the same size on each end. One side is ground and will slip fit into the cover. The other end is ment to fit into the block after drilling. You need to mount the cover and use the newspaper as instructed to get the prper backlash. This will position the cover for drilling the pin holes. Then you use the proper drill/ream to get the dowl pin hole size.
If you look at the pins, you will see what I'm talking about. Do not expect them to fit into the block as-is.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Milidon gear drive, BB with TCI Rattler****UPDATE***** [Re: '72CudaRacer] #652837
03/28/10 12:25 PM
03/28/10 12:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
When I ran the Milidon gear drive I used(and still do)use the Fluidampr..........no problems then or now.
Re: Milidon gear drive, BB with TCI Rattler****UPDATE***** [Re: Thumperdart] #652838
03/28/10 11:20 PM
03/28/10 11:20 PM
Mooresburg, Tn
Mooresburg, Tn
Thanks for the info guys. Another racer near here has a ATI super damper that I'm going to look at monday.
Anyone else have experince with these?
Thanks, Brian
