correct intake for engine??
#652309
03/26/10 10:59 PM
03/26/10 10:59 PM
Posts: 1,559 Oh
His and Her 69's
Oh
I have a 70 bee 383 4 bbl, auto, etc and I need to know if any of these intakes would be correct enough to use for my car?? My original engine is dated 8-26-69, the stamped pad by the dist has - F 383, 3 11, hp on it.
One question is would a 69 intake be correct #2806301 since the casting date on the block is 8-26-69?? or do I need a 70 intake # 2951666 ???
Question #2 my #2951666-1 what does the -1 mean???
and the last question, I have 2 intakes with #2951666 on them and one has a date code of 5.3.9 I assume this one is May 3rd 1969 and the other is 5.02 what are these dates as I can't find the info in my galen white book.
Any Help on these questions would Help me out Greatly. If neither intake is close for my car let me know Please. Thanks David
Re: correct intake for engine??
[Re: His and Her 69's]
#652315
03/29/10 09:42 AM
03/29/10 09:42 AM
Posts: 21,452 It's a dry heat
gtx6970
It's a dry heat
My best guess
Yes you need a 1970 style intake - 69 and 70 take different style chokes
2951666 is correct style 1970 intake
I belive the 1 means core # or core revision
Intakes usually have a 5 digit date code on them , as an example 05039 = May 3rd 1969 so I'm going to leave that one open but my guess is neither is right for your car
[Re: gtx6970]
#652316
03/29/10 10:05 AM
03/29/10 10:05 AM
Posts: 3,980 30 Rock
JS29
30 Rock
[Re: 70 buzz]
#652318
03/29/10 11:44 PM
03/29/10 11:44 PM
Posts: 1,559 Oh
His and Her 69's
Oh
70 Buzz, What number are you talking about that has a -2?? The 2951666 number has a -2 behind it?? The date codes are on the bottom of the intake so I guess no one will see them except me. Thanks Bill for the info. I will use my 2951666-1 intake then. Thanks Guys David
#652319
03/30/10 01:04 PM
03/30/10 01:04 PM
Posts: 1,893 michigan
70 buzz
michigan
my intake reads 2951666-2
