Re: 69 RR SWITCH BEZEL RE-INSTALLATION ! ! !
[Re: foz]
#652144
03/26/10 07:52 PM
03/26/10 07:52 PM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
This won't make it any easier but, cut up a 1 gallon washer fluid bottle [round and white type]. Then use a section/piece as a shim between the panel and the bezel where it is the tightest. You'll have to work/force/ it in still, but it won't gouge the pad if you are carefull/patient. Good luck!
[Re: foz]
#652146
03/26/10 08:45 PM
03/26/10 08:45 PM
Posts: 532 Charlotte, NC
Kowal
Charlotte, NC
I use heavy paper tape on the pad and steering column to make sure I don't scratch them when I am literally forcing, wiggling, tweaking, the switch panel in place.
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: macmic87]
#652148
03/26/10 09:27 PM
03/26/10 09:27 PM
Posts: 1,093 Georgia
Matt M
Georgia
I had a friend help me, I never really saw him get frustrated before. Before this job I mean.
Get a hair dryer put it on high and blast the lower pad. This will heat it up and make it more flexible.
like mentioned above don't tear up the pad or bend up the plate.
[Re: foz]
#652150
03/28/10 09:28 AM
03/28/10 09:28 AM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
Can't do since two of the larger pad fasteners are behind the switch plate. Pad must go in first. I struggled for two hours with mine and finally said, "close enough"
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
