Fuel cell foam questions for street car. #652069
03/26/10 05:40 PM
03/26/10 05:40 PM
In a town not near you.
clownzilla Offline OP
Well I have had my fuel cell functioning for about 2 years now and seems like my foam is degrading and clogging up my fuel system.
I changed my fuel filter today and had some junk in the cup that made it past the filter and my fuel pressure regulator is jumping all over from one minute to the next.
I am not racing the car but I would like to keep the foam so the fuel don't slosh around.
1. Do you know who makes the best quality foam?
2. How long before I replace it again?
3. Is the stuff Summit carries any good?
My tank is 20X24 with a fuel level sending unit.
Here's a pic of the cell.
[image][/image]
The early bird gets the worm, and the second mouse always gets the cheese.
Re: Fuel cell foam questions for street car. [Re: clownzilla] #652070
03/26/10 05:54 PM
03/26/10 05:54 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
I refuse to use foam any more. Kills expensive fuel pumps. I still can't figure out how it gets past the filters...All mine are sumped for decel and acel...
Re: Fuel cell foam questions for street car. [Re: Dragula] #652071
03/26/10 06:00 PM
03/26/10 06:00 PM
I know, I was wondering how it got past the filter too unless there was a whole lotta debris.
I'm gonna tear the filter apart and have a look.
Re: Fuel cell foam questions for street car. [Re: clownzilla] #652072
03/26/10 06:29 PM
03/26/10 06:29 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
along these same lines, I'm having trouble with my sending unit...are these tube style sending units with the floating foam inside the tube that moves a magnent up or down, reliable? my cell has taken on a bit of a "dip" shape to the top of the cell...is it likely that the dip in the top or the foam inside is causing problems? I pulled it out and moved it around manually and it seems to work ok, but I drop it back into the cell and it doesn't seem to work very well.
Today to test it out after "glueing" the magnet back to the foam with RTV (I let it cure for a few days outside the tank before putting it back together) it only dropped to 1/4 tank on the gauge when the tank was empty. added 10 gallons to a "16 gallon cell" that only ever took about 12 to fill up, and it only read 1/2 tank.
I am tired of having an inaccurate fuel gauge!!
can I pull the foam out of the cell? what are the risks of doing that? just having fuel slosh around like it does in a factory gas tank?
**Photobucket sucks**
Re: Fuel cell foam questions for street car. [Re: 70Cuda383] #652073
03/26/10 06:58 PM
03/26/10 06:58 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
i yanked my foam as well.
if that blue an fitting is a vent..
youd better get an extension line on it..or youll have fuel in the trunk floor..
i put a loop in my line then a vent elevated above the highest point in the trunk..
fwiw.
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Fuel cell foam questions for street car. [Re: cheapstreetdustr] #652074
03/26/10 08:05 PM
03/26/10 08:05 PM
I just talked to two of my buddies about this as well and everyone seems to be telling me the same thing...yank the foam out and leave it out but Just make sure you have a vent with a loop.
I'm gonna yank it out tomorrow and flush the entire system, change the brand new filter again since I ran it already with the junk in the system.
Looks like a good time to run to Summit and get a new filter and that Holley gerotor type electric pump that I have been wanting.
Nuther question: The holley gerotor pump is internally regulated, but does this mean I should remove my existing regulator or just leave it in line so I don't have to mess with it?
I guess it won't hurt anything as long as it's not dialed in lower than what the pump is putting out right?
Re: Fuel cell foam questions for street car. [Re: clownzilla] #652075
03/26/10 08:09 PM
03/26/10 08:09 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
you guys who pulled the foam out, you notice any increase in capacity? not enough to even calculate?
Re: Fuel cell foam questions for street car. [Re: 70Cuda383] #652076
03/26/10 08:13 PM
03/26/10 08:13 PM
City of Champions
P
Prostock Offline
Prostock  Offline
P
City of Champions
The foam in the fuel cell in my super bee, and the fuel pump have been in it since before I bought it, and that was quite a few years ago. No problems with either.
Re: Fuel cell foam questions for street car. [Re: 70Cuda383] #652077
03/26/10 08:14 PM
03/26/10 08:14 PM
I'll bet it's more noticeble because the foam is pretty thick, but I'm just guessing.
I'd probably not fill up to the top just to keep the sloshing down.
Re: More fuel cell questions [Re: Prostock] #652078
03/26/10 08:15 PM
03/26/10 08:15 PM
I was thinking that exact same thing until yesterday LOL.
Re: More fuel cell questions [Re: clownzilla] #652079
03/27/10 08:45 AM
03/27/10 08:45 AM
Another question.
I sanyone using one of these?
http://www.summitracing.com/parts/SUM-220020/
It is a vent/filter.
It says 8-an fitting but does not say where you install it.
Would you just screw this directly into the top vent fitting coming out of the fuel cell and be done with it or would you route it somewhere much higher than the cell or what?
Re: Fuel cell foam questions for street car. [Re: 70Cuda383] #652080
03/27/10 09:42 AM
03/27/10 09:42 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
has it always been that way?? did you test the sending unit with an ohmmeter?? the guage and sending unit could be ohm rated differently
i've also had to reattach the magnet..
Re: More fuel cell questions [Re: clownzilla] #652081
03/27/10 10:54 AM
03/27/10 10:54 AM
Another question.
Anyone got any advice on this one?
Re: Fuel cell foam questions for street car. [Re: jughed] #652082
03/27/10 11:05 AM
03/27/10 11:05 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
yes it's always been this way, yes I tested the sender with an ohm meter, and yes it's the same range as the gauge. out of the cell, with the magnet re-attached, the float worked great as I flipped the sender upside down and right side up with an ohm meter on the terminals on top.
inside the truck, it just doesn't want to work! it acts like the float gets stuck inside the tube.
Re: Fuel cell foam questions for street car. [Re: clownzilla] #652083
03/27/10 11:12 AM
03/27/10 11:12 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
What are the disadvantages of removing foam for a street car? Anyone who has removed it noticed problems from not having it in?
Re: Fuel cell foam questions for street car. [Re: Exit1965] #652084
03/27/10 02:39 PM
03/27/10 02:39 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I don't run the foam in mine. For the street think about this... stock gas tanks don't have any foam, why would a fuel cell need it? I haven't noticed any problems with sloshing at the track with mine.
Re: Fuel cell foam questions for street car. [Re: Bigcube] #652085
03/28/10 04:30 PM
03/28/10 04:30 PM
Just an update.
I removed my foam in the cell which seemed to have broken up a few bits but it seemed very pliable and did not break apart with me pulling on it to see if it was brittle but I decided to chuck it anyways.
To answer 70cuda383's question,
I drained the tank completely but the foam blocks retained about a half gallon of fuel by themselves so that much more drained out once I removed it.
One thing I never thought to do which some of you guys may want to consider after getting an aluminum RCI fuel cell is remove the foam before you install the cell and look for metal shavings.
Looks like when they drilled the bung holes for the sump and vents, they never cleaned out the shavings very well and laid the foam in there anyways.
My sump area had about as much aluminum drill shavings as you could fit into a 2 liter Pepsi screw on cap.
Once I got rid of all that crap I decided to replace my Jegs vane type fuel pump with a Holley HP-125 gerotor pump which is so quiet I was really blown away how nice it sounds.
No more, Gggggrrrrruuuuuuummmmmmmmbbbbbllll when I hit the switch.
For the vent, I'm gonna use aluminum fuel line and make an upwards spiral coil coming off the vent with an inline roll over, flapper valve and an inline filter.
Re: Fuel cell foam questions for street car. [Re: clownzilla] #652086
03/29/10 12:55 PM
03/29/10 12:55 PM
Buffalo, MN
hydro Offline
super street
hydro  Offline
super street
Buffalo, MN
The tube sender is very inaccurate because 1) it is too short for most tanks (measure it), and 2) the resistance curve is nowhere close to the curve needed to give a close reading on the gauge. I modified mine to try and match the gauge curve last fall. We'll see how it works this season.
Re: Fuel cell foam questions for street car. [Re: clownzilla] #652087
03/29/10 04:46 PM
03/29/10 04:46 PM
NC
440Jim Offline
440Jim  Offline
NC
Back around 2001 I bought a Summit plastic fuel cell and put it in my Dart. No problems with foam and it is still in there. I ran race gas up to 2007, in 2008, I ran that tank with E85. In 2009, I switched from a carb to Ron's Flying Toilet and belt drive pump. They recommend a front mounted fuel cell, so I bought a 4 gallon one from Summit to squeeze under the hood. I cut a piece of that foam off and put it in a sealed jar with methanol (race alky), and all summer I saw no issue (but I only ran the foam with methanol for a couple weeks). The second half of 2009 I switched over to E85 and put the foam back in. No problems.
I believe one of the functions of the foam is safety in the event of an accident. That is what the info sheet that came with the fuel cell said.
Re: Fuel cell foam questions for street car. [Re: 440Jim] #652088
03/29/10 05:12 PM
03/29/10 05:12 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
right. it said the foam helped to prevent an explosion hazard caused by the fuel vaporizing too fast in the event of a roll over or other crash. the literature said that the fuel could vaporize too quickly, pressurize the tank, and force fuel/fuel vapors out at a high rate and could lead to an explosion
thats probably the only reason I left mine in so far, but...as said...stock tanks don't have foam...
