440 cam button or the cam lock? #651810
03/26/10 12:05 PM
03/26/10 12:05 PM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
Is there such thing as a cam button or cam lock for 440's to keep the cam in place?
Re: 440 cam button or the cam lock? [Re: 74RR] #651811
03/26/10 12:10 PM
03/26/10 12:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
No, nothing to hold the cam in place really. Unless the aftermarket makes something.
Re: 440 cam button or the cam lock? [Re: DaytonaTurbo] #651812
03/26/10 12:22 PM
03/26/10 12:22 PM
74RR Offline OP
74RR  Offline OP
Ok good. I put the new cam in and just started thinking now that I didn't have anything holding the cam in. Just installed the new cam and then the chain.
Re: 440 cam button or the cam lock? [Re: DaytonaTurbo] #651813
03/26/10 12:24 PM
03/26/10 12:24 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
the oil/dist shaft/gear is the camshaft retainer itself since it sits right in front of the cam on BBs
Re: 440 cam button or the cam lock? [Re: 74RR] #651814
03/26/10 12:39 PM
03/26/10 12:39 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
There are big block button kits, and are highly recommended for roller cam engines.
Re: 440 cam button or the cam lock? [Re: 74RR] #651815
03/26/10 01:57 PM
03/26/10 01:57 PM
IMGTX Offline
IMGTX  Offline
A Standard Cam is tapered on each lobe to force the lifters to rotate and it also forces the cam towards the rear of the block. It can't move to the rear because the chain sprocket limits the movement.
Roller Cams are not tapered and require a button to keep the cam from moving around.
Be sure to clean and loctite the bolt on the cam though.
Re: 440 cam button or the cam lock? [Re: 74RR] #651816
03/26/10 04:27 PM
03/26/10 04:27 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Rich H.
Esse Quam Videri
Re: 440 cam button or the cam lock? [Re: ZIPPY] #651817
03/26/10 06:00 PM
03/26/10 06:00 PM
AndyF Offline
AndyF  Offline
But if you had to do it all over again I'm sure you'll use my new cam button next time!
Re: 440 cam button or the cam lock? [Re: AndyF] #651818
03/27/10 08:01 AM
03/27/10 08:01 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
always selling. I like that!
I do like the setup
Andy , I put some ceramic pads on yesterday. Hopefully the white wheels will stay white
Re: 440 cam button or the cam lock? [Re: VanishPt] #651819
02/08/11 12:19 AM
02/08/11 12:19 AM
NY NY
3
340duster340 Offline
NY NY
does your cam button work with oem cover or just your billet piece?
thanks,
Re: 440 cam button or the cam lock? [Re: AndyF] #651820
02/08/11 12:45 AM
02/08/11 12:45 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What's the advantage of yours Andy?
I see a number of cam buttons that bolt in place (and they ain't cheap). What's the point of that over one that just pops into the center? It can't come out once its in there.
Re: 440 cam button or the cam lock? [Re: Stanton] #651821
02/08/11 10:03 AM
02/08/11 10:03 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
It is for adjusting the play, movement, in the cam. It it a PITA to get it right otherwise. Andy's set up would make it a snap. WIsh I had the extra money to get one.
Re: 440 cam button or the cam lock? [Re: Dodgeguy101] #651822
02/08/11 10:06 AM
02/08/11 10:06 AM
michigan
sturmenater Offline
sturmenater  Offline
michigan
there would still be a water pump in the way
