How am I getting water in heater box? #651637
03/26/10 08:04 AM
03/26/10 08:04 AM
Connecticut
LL340Rag Offline OP
LL340Rag  Offline OP
Connecticut
When it rains I am getting water into my heater box in my Challenger. It just started happen in our 7 inch deluge last week. Where would it be coming from? No leak in the heater core and it's just water not anti-freeze.
Re: How am I getting water in heater box? [Re: LL340Rag] #651638
03/26/10 08:20 AM
03/26/10 08:20 AM
NJ
440challenger Offline
NJ
Maybe the cowl has a rust hole right where the duct seals to the cowl on the inside
Re: How am I getting water in heater box? [Re: 440challenger] #651639
03/26/10 08:33 AM
03/26/10 08:33 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
There is a large lip above the duct. This would have been an extremely tough area to get paint or anything else into either by the factory or anyone else. quite likely its finally rusted through. You may be able to get your hand up there if you pull the heater grill off. Otherwise you'll have to drop the heater.
Re: How am I getting water in heater box? [Re: LL340Rag] #651640
03/26/10 08:35 AM
03/26/10 08:35 AM
MotorCity
RC91 Offline
RC91  Offline
MotorCity
Make sure the cowl drains are open and it isn't filling up and running over into your heater.
Re: How am I getting water in heater box? [Re: RC91] #651641
03/26/10 09:16 AM
03/26/10 09:16 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Exactly, I remove the cowel screens from time to time and use a shop vac. You can use air hose to blow out the drain holes too, I think there are 3 of them. Then I use the shop vac again to suck out whatever I moved around with the air hose.
Re: How am I getting water in heater box? [Re: Challenger 1] #651642
03/26/10 08:58 PM
03/26/10 08:58 PM
Connecticut
LL340Rag Offline OP
LL340Rag  Offline OP
Connecticut
The car has basically no rust and has been garaged since 1986. Most likely the drains are clogged since we had 70 MPH wind and the leaves were everywhere the one night I couldn't get it back in the garage.
Re: How am I getting water in heater box? [Re: LL340Rag] #651643
03/29/10 07:07 AM
03/29/10 07:07 AM
Connecticut
LL340Rag Offline OP
LL340Rag  Offline OP
Connecticut
I took about 5 minutes and just blew out everywhere I could get the hose in and so far so good. 3-6" of rain today so we'll see. So far so good.
Re: How am I getting water in heater box? [Re: LL340Rag] #651644
03/29/10 07:57 AM
03/29/10 07:57 AM
Cincinnati, Ohio
Cincinnati, Ohio
It sucks that it has to sit in the rain, didn't the car earn the right to be sheltered by now in it's life?
