P5007668 block #651632
03/26/10 07:53 AM
03/26/10 07:53 AM
Ohio
john55 Offline OP
john55  Offline OP
Ohio
is this hemi block a 4.25 or 4.5 bore? can't find any info at the moment
The Plymouth Win You Over Beat Goes On
Re: P5007668 block [Re: john55] #651633
03/26/10 09:26 AM
03/26/10 09:26 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It's a water block originally honed to 4.25.
Superseded to P5007668AB in 2004.
Superseded to P5155072 in 2007.
P5155072 is the current part number, which is no longer a water block (it's siamese) but has the same bore dimension.
Rich H.
Esse Quam Videri
Re: P5007668 block [Re: ZIPPY] #651634
03/26/10 09:30 AM
03/26/10 09:30 AM
Ohio
john55 Offline OP
john55  Offline OP
Ohio
thanks, Zippy!
