Re: Another heap coming back together1
[Re: instigator]
#651382
03/26/10 07:59 AM
03/26/10 07:59 AM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
Looks good, I know your ready to make a pass its been a while.
One day I will have something cool here.
[Re: sdaurity]
#651383
04/06/10 11:15 PM
04/06/10 11:15 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Stuck the motor in the bay saturday to test fit the new headders...also to see if the new turbos had room...got one last week to give it a once over, #2 suppose to be here Friday...basically a gt4202 replacement turbo...I know it is not an actual Garrett but I only bought 1 to begin with to check it out...to me there are 10's of thousands gt42's running around on big diesels so that means there are tons of turbos to replace....this turbo has the signs of a heavy truck replaceemnt turbo... 74.2mm compressor inducer, 102mm exducer 82/75mm turbine wheel 1.05 turbine A/R
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: RockChip]
#651385
04/07/10 03:29 PM
04/07/10 03:29 PM
sdaurity
North Cackilacky
Twins, Makes me want to buy an aftermarket block and another 88. One day. Hope it doesn't give you to many headaches.
[Re: sdaurity]
#651386
04/08/10 02:27 PM
04/08/10 02:27 PM
Posts: 452 nc
cold85
nc
[Re: Twostick]
#651388
04/11/10 12:26 AM
04/11/10 12:26 AM
instigator
north cakalaky
I believe quite a few detroit diesel 60 series engines used either garrett gt42's, s400's....(has to be somewhere in the later 90's I believe though...
[Re: RylisPro]
#651391
04/13/10 07:37 PM
04/13/10 07:37 PM
instigator
north cakalaky
Manley 14355C-8 Pro-series rods
