radiator swap??? #651127
03/25/10 06:28 PM
03/25/10 06:28 PM
Lockport, New York, USA
ramified Offline OP
ramified  Offline OP
will a 1949 dodge truck 1 1/2 ton truck radiator fit into a 1952 1/2 ton? they do look the same. trying to find a 52, isnt the easiest search. they both look the same. any ides/help?
Re: radiator swap??? [Re: ramified] #651128
03/25/10 08:29 PM
03/25/10 08:29 PM
moparx Online content
moparx  Online Content
according to my interchange, 48-53 B & 100 series takes #435. 48-50 C & 200 series and 48-53 D & 300 series takes #436. however the 51-53 C & 200 series took the #435 same as the 48-53 B & 100 series. my guess is what you have will work.
Re: radiator swap??? [Re: moparx] #651129
03/26/10 11:00 PM
03/26/10 11:00 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If your not keeping it all stock, I drilled a couple holes and mounted a 3 core 70s truck rad to my 50 rad support. Gene
Re: radiator swap??? [Re: moparx] #651130
03/29/10 04:53 PM
03/29/10 04:53 PM
ramified Offline OP
ramified  Offline OP
well, i just compaed the two radiators, and for the most part, they look the same. the only difference i see is the mounting brackets are different. the guy found my post on cl. two weeks ago, been screwing me around and now put me in touch with his buddy that has it. he wants $250.00 firm for it. it has been sitting for about 10 years . oh, what to do?
Re: radiator swap??? [Re: ramified] #651131
03/29/10 06:27 PM
03/29/10 06:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Most radiator companies have thier catalog online. I'd measure out what you have and see if something looks like it could be adapted to your setup. That's how I figured out a HD radiator from an 87 Ram would fit my 87 Diplomat.
Don't be the exception.
Re: radiator swap??? [Re: ramified] #651132
03/29/10 08:44 PM
03/29/10 08:44 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
For $250, I'd buy something modern and adapt it in, then never look back. But thats just me. Gene
Re: radiator swap??? [Re: poorboy] #651133
03/29/10 08:52 PM
03/29/10 08:52 PM
me too ! for 250, i would get a latemodel replacement or a good used cheapy and drill a couple of x-tra holes.
