Re: milodon oil pump
[Re: HEMI472]
#650847
03/25/10 10:50 AM
03/25/10 10:50 AM
Posts: 4,254 State of Fascism
52savoy
State of Fascism
It's bleeding off because it's not sealed somewhere. You can either try to tighten the fittings more or .. 1.take it apart and clean all the oil off 2.put a sealer on the threads and reassemble(Gray Permatex ) I put JB weld on the pan bulkhead fittings because the O-ring seems to be a common problem.
[Re: rowin4]
#650849
03/25/10 11:38 AM
03/25/10 11:38 AM
52savoy
State of Fascism
yeah..this came up last year in a post.. a longer line with sort of an horizontal "S" will work. Don't take this as an insult or anything but..to me that seems to be overlooking a bigger problem of not sealed somewhere. I've been using Milodon's for decades and never had that problem as long as it was sealed up. Believe me, I've taken them apart and reassembled them many.. many times before getting it sealed so it would prime. But now I use better sealer and the oil pressure always comes up while the car is cranking over. I did have have a problem one time where the car had sit 4 years and wouldn't prime. But these are my views and don't amount to a hill of beans
[Re: Bigcube]
#650852
03/26/10 08:53 AM
03/26/10 08:53 AM
Posts: 8,903 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
This has been a known problem since the '70's and has nothing to do with sealing up. If sealing were the issue then you'd be drawing air into the pump with the oil - definately NOT GOOD!
On a stock pump the feed line comes up through the block and down into the pump. No matter what, it will hold some prime.
However, with the Milodon pump setup either the single or dual lines both feed up and into the pump. When the engine is off, the oil just runs back to the pan.
Of course in order to do this it needs to have air bleeding in from somewhere - like around lifters, cam bearings, rockers, etc.. And any oil below the pump will bleed off - like around the crank.
The bleeding off speed will depend on the thickness of oil and how much your clearances are.
The solution was mentioned ... run the lines so a section is above the pump. Another solution would be a -12 check valve in each line (Summit - not cheap!)
[Re: Stanton]
#650853
03/26/10 11:19 AM
03/26/10 11:19 AM
52savoy
State of Fascism
If that's the case, why do my Milodon pumps ALWAYS prime themselves? I don't do anything with the lines. Please explain it to me because I really want to know? Maybe it's karma but really, I've been using Milodon oiling systems since the early 70s..almost 40years. If you can give me a reason why I went from having those problems..to not having any, please give me a reason that makes sense.
[Re: 52savoy]
#650854
03/26/10 05:33 PM
03/26/10 05:33 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
They'll prime themselves alright ... how LONG it takes to prime is the issue! The engine should have pressure almost instantly when it fires. If the pump takes a couple seconds to prime and build pressure then there's potential for wear in the motor.
So you solved "your" problem by sealing a leak. Great! But that's not the most common cause for loosing the prime.
[Re: HEMI472]
#650859
03/27/10 12:42 AM
03/27/10 12:42 AM
Posts: 31,068 Oregon
AndyF
Yep, Milodon pumps are well known for losing their prime. If everything is nice and tight and you loop the oil line properly it will help to stay primed. The sure fire solution is to plumb in an Accusump setup but that is extra money, weight and space.
Here is one of my favorite pictures. It shows a nice clean setup that maintains prime really well.
[Re: HEMI472]
#650861
03/28/10 12:11 PM
03/28/10 12:11 PM
It is also possibe that a small piece of debris got in the ppump and scarred the cover or gears. This will cause pump to lose it's prime. I had a needle bearing from a rocker pass through and cause
