Pinion Angle #650842
03/25/10 10:37 AM
03/25/10 10:37 AM
NE
moparpoolman Offline OP
NE
What should the pinion angle be on a 68 B body 4spd Dana with SS springs be? How should it be measured? Is there a link to goto for this? Thanks
Re: Pinion Angle [Re: moparpoolman] #650843
03/25/10 11:41 AM
03/25/10 11:41 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
The May Hot Rod has a good illustration of it.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Pinion Angle [Re: Junky] #650844
03/25/10 11:43 AM
03/25/10 11:43 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Our tech archives has some info on it. http://www.moparts.org/Tech/Archive/rearsusp.html
Re: Pinion Angle [Re: moparpoolman] #650845
03/25/10 11:55 AM
03/25/10 11:55 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
M P chassis manual calls for 5-7* pinion down. This angle is relative to the driveshaft, not the ground. The factory had a service tool made by Miller tool co. for measuring this angle. Using this tool you would have 5-7* positive angle at the pinion, front angle should be negative. FWIW this is the preferred angle for drag racing, not everyday use.
