Holley red electric fuel pump problems #650631
03/24/10 10:47 PM
03/24/10 10:47 PM
San Jose, CA
Blue69Charger Offline OP
San Jose, CA
I've had my holley red electric pump for about 8 years. It never had any problems. I have the ground wire connected to a ring connector bolted to the passenger side of the shock crossmember where the fuel line clamp used to screw into. Over the weekend I noticed the screw was sloppy so I replaced it with a regular bolt, nut and star washer. Now at random it won't return to idle. It will stay at 2,000 rpm and have a -10 amp draw. I tried taking the bolt out and sanding the cross member down to bare metal and reattaching the bolt. It still does the same thing. I checked my throttle linkage and it doesn't appear to be sticking. The choke is off when it does this. Could the relief valve on the pump be sticking, or is it something electrical related?
Re: Holley red electric fuel pump problems [Re: Blue69Charger] #650632
03/25/10 12:44 AM
03/25/10 12:44 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The fuel pressure won't cause the high idle problem. In fact if the pump had a bad ground it would lose fuel pressure. I also have good luck with the red pump as I run one on my 63 and one on my sons Dart. But you may want to check for a vacum leak also for the high idle or the fast idle cam sticking. Ron
Re: Holley red electric fuel pump problems [Re: Blue69Charger] #650633
03/25/10 12:47 AM
03/25/10 12:47 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
You know the same thing happen to me when I got a zit on my nose. Turns out they were not related.
I kind of doubt your one problem is related to the other unless maybe you changed something else at the same time.
Maybe a vacuum leak?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Holley red electric fuel pump problems [Re: HealthServices] #650634
03/25/10 08:21 PM
03/25/10 08:21 PM
San Jose, CA
San Jose, CA
I didn't touch anything under the hood before it happened. I took the air cleaner off and made sure the chokes were off when it was doing that. Could the pump short it self, raise the fuel pressure, bypass the needle valves and raise the idle? There is no fuel pressure regulator. The ammeter discharges when the idle goes up so I think its fuel pump related.
Re: Holley red electric fuel pump problems [Re: Blue69Charger] #650635
03/25/10 08:57 PM
03/25/10 08:57 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If the fuel press went to high it would just cause gas to drip from the nozzle's and flood the eng as it would run bad and be hard to keep running. It would not cause the idle to raise. It sounds like it stops charging and takes that small load from the alt away and can cause the idle to raise some as you said it stops charging. I would actually check the charging sysem and make sure the body ground is good as maybe the body ground is bad and it was finding a ground thru the fuel pump ground ?? Ron
Re: Holley red electric fuel pump problems [Re: 383man] #650636
03/25/10 11:43 PM
03/25/10 11:43 PM
San Jose, CA
San Jose, CA
Thanks for the suggestions Ron. I'll check the firewall ground and charging system.
Re: Holley red electric fuel pump problems [Re: 383man] #650637
03/27/10 07:37 PM
03/27/10 07:37 PM
San Jose, CA
San Jose, CA
When it was charging I unplugged the wires from the voltage regulator (70-up style) and it discharged but did not notice a drop in idle. I unplugged the ground from my fuel pump relay when it was discharging and it still discharged. I removed the paint from the firewall and head under the ground strap terminals and made sure the bolts were tight. When it was discharging the positive field wire had 12V. Both the positive and negative field wires had less than .3 ohms of resistance from the alternator terminals to the voltage regulator. I noticed the discharging usually starts at higher rpms when it is warm. I tightened the belts, but the problems remains. Any idea what else could cause a simultaneous increase in idle speed and discharge?
Edit: I ran the engine when it was starting to get dark. I can see arcing in the alternator when its charging. If I take it up to 2-3,000 rpm it will start discharging for a few minutes. There is no arcing in the alternator when it discharges.
Re: Holley red electric fuel pump problems [Re: Blue69Charger] #650638
03/27/10 11:52 PM
03/27/10 11:52 PM
So Cal
So Cal
If the Alternator is not charging you will have a discharge, furthermore if the alternator is not charging it will not be putting a load on the motor so the idle will be higher than when it is charging.
Re: Holley red electric fuel pump problems [Re: HealthServices] #650639
03/28/10 12:12 AM
03/28/10 12:12 AM
San Jose, CA
San Jose, CA
Thanks HealthServices. I think the idle increase is most likely due to alternator not charging. But when the idle was normal (900rpm) and it was charging properly, why was I able to disconnect the voltage regulator harness without the idle speed increasing?
Re: Holley red electric fuel pump problems [Re: Blue69Charger] #650640
03/28/10 10:28 AM
03/28/10 10:28 AM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
what is the rpm difference between idle before and after burnouts?
Re: Holley red electric fuel pump problems [Re: SixDRacing] #650641
03/28/10 06:57 PM
03/28/10 06:57 PM
San Jose, CA
San Jose, CA
Thanks guys. My alternator is bad. One of the brushes came loose so I am just going to exchange it.
