hey james..long time no see
yea,I would unhook the fuel line and run it to a small can on the ground and run it some to clear the cyls
may need a set of plugs also
sitting and bad gas is a givin...may need the carb opend and clead out
when gas evaps in one it will leave all kinds of grainulary sediments from the gas that will clogg them up also
if the carb was not pluged it would deff be bad gas after that long of a time
what does it smeel like at the gas cap?
just smell dont huff
try those first IMO
fresh gas is a must after sitting that long
