84 van 318 2bbl #650307
03/24/10 05:01 PM
03/24/10 05:01 PM
Winterville, Ga USA
rogue_leader007 Offline OP
Winterville, Ga USA
I've just been given a 84 b-250 van with a 318. The van sat for 3 years, and now it pops and skips horribly when I take it down the road. It makes the whole van jerk around pretty violently.
Could this be condensation in the gas tank, or something a simple tune-up could fix?
Thanks for any info.
Glad to be back in the hobby.
68 Plymouth Valiant
Re: 84 van 318 2bbl [Re: rogue_leader007] #650308
03/24/10 05:48 PM
03/24/10 05:48 PM
Pull the plugs and see what they look like and pull the carb top & eyeball the bowl (debris/water globules)
Re: 84 van 318 2bbl [Re: RapidRobert] #650309
03/24/10 05:54 PM
03/24/10 05:54 PM
Andrewh Offline
Andrewh  Offline
if you didn't, I would dump all the gas out and get fresh gas into the system and see what that does.
Re: 84 van 318 2bbl [Re: Andrewh] #650310
03/24/10 06:11 PM
03/24/10 06:11 PM
Last year a womans lawnmower wouldn't start and the carb bowl gas looked like brown tea.Drained it/fresh gas/started right up and it only sat over the winter (several months tops). Todays gas is worthless (in several areas).
Re: 84 van 318 2bbl [Re: RapidRobert] #650311
03/25/10 10:36 AM
03/25/10 10:36 AM
scratchnfotraction Offline
hey james..long time no see
yea,I would unhook the fuel line and run it to a small can on the ground and run it some to clear the cyls
may need a set of plugs also
sitting and bad gas is a givin...may need the carb opend and clead out
when gas evaps in one it will leave all kinds of grainulary sediments from the gas that will clogg them up also
if the carb was not pluged it would deff be bad gas after that long of a time
what does it smeel like at the gas cap?
just smell dont huff
try those first IMO
fresh gas is a must after sitting that long
Re: 84 van 318 2bbl [Re: scratchnfotraction] #650312
03/25/10 10:56 AM
03/25/10 10:56 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
After cleaning out the fuel system, check out the motor too.
do a compression check and check for timing chain slop. Do a good tuneup to wake it up.
Re: 84 van 318 2bbl [Re: RodStRace] #650313
03/25/10 11:15 AM
03/25/10 11:15 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Just what I was going to suggest. If it's got crap compression or the timing chain is shot, no amount of spark plugs and fresh gas will cure that.
Re: 84 van 318 2bbl [Re: rogue_leader007] #650314
03/25/10 05:10 PM
03/25/10 05:10 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
Check the distributor cap and rotor really good for any corrosion "growth" as this can cause some radical misfiring if any moisture built up in there and corroded the copper or alluminum contacts. Good luck!
Re: 84 van 318 2bbl [Re: rogue_leader007] #650315
03/25/10 09:09 PM
03/25/10 09:09 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
I would look at the cap/rotor and pickup coil first, if it runs at all the fuel most likely isn't the problem.
Re: 84 van 318 2bbl [Re: MoparJoe] #650316
03/26/10 11:07 AM
03/26/10 11:07 AM
Winterville, Ga USA
Winterville, Ga USA
Thanks for the info.
Another thing is that it'll idle great, but as soon as you put it gear, it'll want to stall. I had a chebbie pickup that would do that too a couple years back, and a set of new plugs and wires really helped.
The "ram-rod", as I call it, does great a lower rpms, but as soon as you get up to cruising speed, the pops and jerks begin. And I swear I can hear backfire noises coming from the air cleaner.
Thanks again for any help.
Hope that tranny you got from me is working out for ya scratchin'.
68 Plymouth Valiant
Re: 84 van 318 2bbl [Re: rogue_leader007] #650317
03/31/10 03:26 PM
03/31/10 03:26 PM
Winterville, Ga USA
Winterville, Ga USA
Could a stopped up catalytic converter be the problem by any chance?
68 Plymouth Valiant
Re: 84 van 318 2bbl [Re: rogue_leader007] #650318
03/31/10 04:13 PM
03/31/10 04:13 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
Is there any diff on the way it runs ... when the engine is cold .. or hot ?
