Brake Problem
#65014
05/28/08 09:47 AM
05/28/08 09:47 AM
Posts: 163 Beautiful Downtown Bahama, NC
tact1
I have a Line Lock installed on my front brakes, using the stock Challenger distribution block. Recently when I try to use it, when I take my foot off the brake with the lock engaged, the rear wheels will not release. Have I got a bad distribution block and if so, where do I get another?
"Four out of three people have a problem with fractions"
Re: Brake Problem
[Re: mikemotorhead]
#65016
05/28/08 12:51 PM
05/28/08 12:51 PM
tact1
No, they are not hooked up wrong. I used them last season and so far this season they were ok, but just the outing before last they did it once, and last week it was constant. I have checked all the connections and they are correct.
Re: Brake Problem
[Re: tact1]
#65018
05/28/08 02:00 PM
05/28/08 02:00 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
When I bought my line lock years a go they mention that style I had was rebuildable. I never saw a rebuild kit for those things but I think they are cheap enough to be easily replaced. If you have a battery voltage to the line lock and a good ground for the unit I would replace the line line lock with a new one.
Did you wire it switch to ground or switch to power?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
