small-block stroker oil pan leaks #649731
03/23/10 11:09 PM
03/23/10 11:09 PM
BC Canada
cudasam Offline OP
cudasam  Offline OP
BC Canada
I have a 406 magnum stroker in an e-body, and I can't seem to stop the oil pan from leaking at the rear. I have tried a stock 360 pan with a one-piece magnum gasket, and then I tried a stock size aftermarket pan with a Mopar 360 LA gasket set. This worked great for a few days ,until my motor started to break in .it seems like when I started hitting higher rpm's, the leak started again. I have no windage tray, so is it possible the crank is spinning in oil under acceleration and getting forced out under pressure? Should I just bite the bullet and go with a Milodon low profile? Thanks.
Re: small-block stroker oil pan leaks [Re: cudasam] #649732
03/23/10 11:26 PM
03/23/10 11:26 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Changing pans isn't going to fix the problem. Any pan with straight rails and proper installation should work. Are you sure the oil isn't coming from another location? Rear main seal or even oil sending unit? Are you overfilling the pan? If so I'd stop it today.
Re: small-block stroker oil pan leaks [Re: cudasam] #649733
03/23/10 11:45 PM
03/23/10 11:45 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
I had the same problem on my 408 on a small scale. I am trying a Milodon low pro pan now, but don't have it back in the car yet.... so I'm not any help...
Re: small-block stroker oil pan leaks [Re: PAINT IT BLACK] #649734
03/24/10 01:12 AM
03/24/10 01:12 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The one piece magnum type gasket doesn't fit the older blocks 100% correctly. Something about the corner to pan connection needing spacers.
I put one in my 360 and the rear cap to pan didn't seem right at all.
Re: small-block stroker oil pan leaks [Re: autoxcuda] #649735
03/24/10 10:48 AM
03/24/10 10:48 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
If you didn't put a thin film of RTV sealer between the block and rear main cap it could be leaking there.
Re: small-block stroker oil pan leaks [Re: 69Cuda340S] #649736
03/25/10 06:24 PM
03/25/10 06:24 PM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
I have the exact same issue with my 408. I have had the pan off now two times. The last time I used the Kevco pan and magnum gasket. One time it leaks alot the next time very little. I figure it has to be the rear main as everything else is dry. I've built plenty of small blocks (318's and 340's) and never had this problem. The worst part of the whole mess is it didn't leak a drop through 8 dyno pulls and then leaks as soon as installed in the vehicle.
