Door panel wrinkle removal Q #64944
05/28/08 12:48 AM
05/28/08 12:48 AM
The Sunny Shuswap
dodgefarmer Offline OP
The Sunny Shuswap
I have the standard wrinkled interior door panels. Any ideas on how to remove the wrinkles?
Randy
Re: Door panel wrinkle removal Q [Re: dodgefarmer] #64945
05/28/08 08:40 AM
05/28/08 08:40 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
vinyl is no longer glued to the backer board.
Re: Door panel wrinkle removal Q [Re: dodgefarmer] #64946
05/28/08 09:15 AM
05/28/08 09:15 AM
WI
RestoRick Offline
RestoRick  Offline
WI
Randy
Warm the vinyl with a heat gun to soften it, then you can pull it slightly and re-glue it on the
backside of the panel.
Use some spring clamps and a couple sticks to clamp it overnight.
Rick
Re: Door panel wrinkle removal Q [Re: RestoRick] #64947
05/28/08 09:36 AM
05/28/08 09:36 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I did that with an old set of dart swinger door panels. I pulled the vinyl tight and used a hot glue gun to reglue them. Dries fast and holds tight unlike some of the upholstery adhesives I have used before.
Re: Door panel wrinkle removal Q [Re: Neil] #64948
05/28/08 11:07 AM
05/28/08 11:07 AM
The Sunny Shuswap
The Sunny Shuswap
Thanks guys.
Randy
Re: Door panel wrinkle removal Q [Re: dodgefarmer] #64949
05/28/08 12:46 PM
05/28/08 12:46 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
For wrinkles more toward the middle I have wetted them and then put them in the direct very warm sunlight and have had luck with getting them to shrink back tight. But for the edges yes by all means restretch them and reglue behind the board. Good luck.
