Re: How much $ to assemble a long block?
[Re: MoparBilly]
#649031
03/24/10 05:26 AM
03/24/10 05:26 AM
Posts: 998 Clinton Township, Michigan
Dartin
We do it like this: Proud owner of engine comes home with all his parts from the machine shop... Buys Pizza and Beer, and calls us all over... After many stories, and proper lubrication, 4 or 5 drunk monkeys put it all together... Cam break-in commences at 1AM!!
When we do it we use the grease from the pepperoni for cam break-in and bearing lube
[Re: dOc !]
#649032
03/24/10 08:00 AM
03/24/10 08:00 AM
Posts: 4,091 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Well ...a drunk MONKEY could put together the SB then.
That is CrAzY .... what kind of knowledge or expertise is there just doing that ?
I'm not sure if your kidding or not Doc? If not, then you'd be insinuating Ron Silva is crazy or silly for verifying dimensions during assembly using the premier R&R rods. And that is merely one example. What about the thru-machined balance ho le in the crankshaft that BG racing found, from what I remember the journals were machined properly. IMO most posts critical of building charges are the result of, and excuse the word, ignorance. Any assembly or labor should be charged by the time required. All the experts out there just need to do the work themselves but, they'll have the burden of responsiblity when something goes wrong. Don't forget the overhead of specialized tools too.
[Re: HardcoreB]
#649033
03/24/10 10:26 AM
03/24/10 10:26 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Hardcore, Ron IS crazy!!!!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: jamesc]
#649036
03/24/10 03:03 PM
03/24/10 03:03 PM
Posts: 573 PA
68CudaB1
PA
His prices are always very competitive.
i looked at his whole price sheet and if it's quality work i would say that's putting it mildly
Top quality machine work PLUS his prices on parts can not be beat. He has basically no markup on parts, and purchases alot so that keeps prices down for his customers. And he is HONEST, his price sheet is filled out with you and that is what is done and billed, simple as that.
[Re: HardcoreB]
#649037
03/24/10 06:19 PM
03/24/10 06:19 PM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
NO ...I am not kidding Sean. If everything is checked and set(like ring end-gaps, bearing clearances, cam degreeing, etc, ETC) ....I will still STICK with what I said. All you need to know what to use is a torque-wrench and a ring compressor.
Is Ron CrAzY ? ... like that guy from North-of-the-border ?? ... NO. CrAzY like-a-FOX? - maybe ! I guess it all boils-down-to ...whatever the market will bear.
Now I would think it depends on who you go to. You go to Joe-Blow Speed Shop(who you know does good-work) ... who does all the checking, filing and verifing AND assembling ... 750$(plus the maching costs) .. I say is reasonable. I would not pay that ... I am capable of doing this me-self.
Now go-to someone like WJ(who is famous for doing his own stuff) .... to do the SAME WORK .....
You would probably pay 4 TIMES that.
Just my
[Re: dOc !]
#649038
03/24/10 07:16 PM
03/24/10 07:16 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
No matter what machine work is done by whom ever,when some one brings a engine to our shop just for assemble we treat it as a complete build.We recheck every journal,rod,piston,rings,bores,deck,valve job,spring pressure and height,crank and cam end play and clearences as well as the kitchen sink before before,during and after.We log and inform the customer of our findings.The final assembly is just as important as any early stage of work.The best parts can be damaged by shoddy assembly and the assembler better be on of your shops best and smartest guys,he will catch the mistakes before the engine leaves and the customer won't be the one to suffer.As I have said before I have great machinist that work for me,but would never let them "build" an engine.To have a set rate cast in stone is like playing Russian Roulette.One engine with bad machine work can cost a builder days or more to correct.We evaluate each job on individual basis and keep the customer informed.
[Re: B G Racing]
#649039
03/24/10 07:51 PM
03/24/10 07:51 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
i agree with this....when/if the builder finds something wrong.it has to be fixed..that cost money..you might assemble 5 items and they are without issue.. then you get to the "R&R" rods ..and all hell breaks loose... there is a hassle factor..and then there is a HASSLE Factor... find someone you trust..who wont throw an unexceptible part in there..and he'll be worth every penny. cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#649040
03/24/10 08:13 PM
03/24/10 08:13 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
A basic naturally aspirated single 4 barrel, cast intake motor, intake to pan I charge $850..... that includes checking all bearing clearances, file fit rings, degree cam, measure for custom P rod length, check piston to valve clearance, both radially & vertically, lash valves for fire up, prime oiling system (not including oil/filter etc).... & I charge an extra $65 to clean & assemble the heads separately. So technically I guess it's $915.
Then if it's more complicated deal with alot of external oil/water lines, etc that external stuff gets charged $ per hour & added ontop of normal assembly fee.
