Fuel Tank Sender Unit #648984
03/23/10 01:31 PM
03/23/10 01:31 PM
Eastern North Carolina
riverman Offline OP
riverman  Offline OP
Count me on the list of people with a replacement fuel tank sender unit that reads up to half (sometimes) on a full tank. Question: How does one measure the resistance of the fuel sender at various levels with it in the car? Disconnect the wire at the sending unit and measure across ground, or have the fuel system energized by the ignition and measure at the sending post to ground (that sounds like a short) or some other way. This is in a 69 B body so getting up to the pin on the dash is not possible. Thanks
Re: Fuel Tank Sender Unit [Re: riverman] #648985
03/23/10 01:49 PM
03/23/10 01:49 PM
Andrewh Offline
Andrewh  Offline
if you measure at the post and then the body of the sending unit you should get the resistance measurement.
10 -73 or 78 as I recall.
Re: Fuel Tank Sender Unit [Re: Andrewh] #648986
03/23/10 01:51 PM
03/23/10 01:51 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
69 B Body, I've been on the list for years.
Re: Fuel Tank Sender Unit [Re: DennisH ] #648987
03/23/10 01:54 PM
03/23/10 01:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You will still have to pull the sending unit out of the tank to measure resistence. How are you going to move the float arm through it's arc if you can't get to it?
Re: Fuel Tank Sender Unit [Re: stumpy] #648988
03/23/10 02:05 PM
03/23/10 02:05 PM
riverman Offline OP
riverman  Offline OP
Over time - full tank, measure a few times on the way down, get close to empty with a five gallon tank of gas in the trunk. Hopefully it is linear so I predict the zero point.
I think I also have a problem with a voltage regulator on the dash (that is a recent pop up). Since the amp and oil gauge has been replaced by aftermarket underneath, (all period correct sunpro), thinking of getting a fuel level gauge with the correct ohms measure full and empty , and installing it in the console out of sight.
Re: Fuel Tank Sender Unit [Re: riverman] #648989
03/23/10 02:16 PM
03/23/10 02:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You are going to be guessing at best. It's not that hard toi pull the sender and bench test it to be sure. You may just need to bend the float arm to get it to read correctly.
Re: Fuel Tank Sender Unit [Re: stumpy] #648990
03/23/10 04:09 PM
03/23/10 04:09 PM
Az
Crizila Offline
Crizila  Offline
Az
Yes, you are probably going to have to pull the sender, but before you do: Check all the wiring to the sender. Make sure the sender is grounded to the frame ( powered idiot ligt or ohm test ). Check to make sure the voltage limiter is working properly - to test it in the vehicle, connect one volt meter lead to the temp sender and the other to a good ground ( leave the temp sender wire connected to the temp stud ). Turn the ignition to ON. The volt meter will fluctuate if the limiter is functioning. If the wiring and the voltage limiter check ok, pull the sender. Oops, you did make sure the tank was full of gas when you only read half right???? - and the tank does not have any major dents / deformed. Ok, pull the sender and hook it back up with a good chassis ground. Run the float from its empty stop to half, and to its full stop and have someone watch the gauge. If the gauge reads correctly, the float overall travel is not the sanme as the original one and will need to be adjusted accordingly. If the gauge does not read empty to full with full float travel: The tank sender may be bad or the wrong one ( check for smooth travel operation with an ohm meter ). Wiring between the gauge sending unit and the dash circuit board ( including the the multi-connection junction )could be bad. Circuit board could be bad. Dash gauge could be bad.
Fastest 300
