Re: Calling all ignition problem/possessed vehicle experts.
[Re: Dusted_Ya]
#648460
03/23/10 12:45 AM
03/23/10 12:45 AM
Posts: 2,005 s. e. pa.
calrobb2000
s. e. pa.
hi what plugs , pn ? what are you towing , total weight ? carb type , size ? intake type ? timing setting, curve ? convertor , stall? ????????
[Re: calrobb2000]
#648461
03/23/10 12:55 AM
03/23/10 12:55 AM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Can you please show us some pics of the engine? Where is it timed? Good ignition system, but fireworks are not good...under the hood anyway...
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: GTXX]
#648464
03/23/10 07:48 AM
03/23/10 07:48 AM
Posts: 5,270 Missouri
MY340
Missouri
Place a heat shield in front of your master cylinder to block the header heat.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: Dusted_Ya]
#648465
03/23/10 07:54 AM
03/23/10 07:54 AM
Posts: 1,051 Slidell, La.
doctor_mopar
Slidell, La.
Accel Super Stock wires are very cheaply made garbage ! I would also suspect you may have excessive voltage output from the alternator. A simple check with a volt meter would tell.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: sunroofgtx]
#648467
03/24/10 11:50 PM
03/24/10 11:50 PM
Posts: 857 The Dalles, OR.
Dusted_Ya
The Dalles, OR.
Sorry for the delay in response but I HAD to get this truck running again so I went to Schucks/O Reilly auto parts and picked up the most expensive plug wires the had on hand which were the MSD super conductor wires. Sorry SunroofGTX I promise next time I need plug wires I'll order through you. I just absolutely couldn't wait. I had to tow my stranded trailer loaded with lumber before it disappeared... I called Pertronix and asked them about the plug wire dilema and they said basically what you guys said. The ignition system wants to send 60,000 volts to the spark plug and if it can't it fries the wires... which it did. Anyways the MSD's weren't my first choice but they seem to be far far better than the stupid Accels I had on. And the truck ran great. I also used some aluminum from pop cans to wrap around my headers for heat shields near the plug wire boots and completely encased each plug wire in wiring loom tubing. Looks redneck as f@#k but at this point I don't care if it works. If it don't I'm probably going to have to go back to stupid exhaust manifolds.
