Ebody disk brake spindle service measurements???
#647624
03/22/10 08:10 AM
03/22/10 08:10 AM
Posts: 15,491 the boonies
aarcuda
the boonies
Are there measurments for the spindle diameter where the bearings sit? I have a little bearing slop after greasing and adjusting my front wheel bearings. The spindle looks a little worn where the puter bearing rides so I'd like measure it
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Ebody disk brake spindle service measurements???
[Re: aarcuda]
#647625
03/22/10 04:59 PM
03/22/10 04:59 PM
aarcuda
the boonies
maybe I can ask a different question-
anyone know what the clearance is between the bearings and the spindle? I know there has to be some slight clearance so the inner race wont turn but what is it?
[Re: 05dakota]
#647628
03/22/10 09:49 PM
03/22/10 09:49 PM
aarcuda
the boonies
unless the spindles is noticably woren , scored etc, i cant believe its wore .
i tried taking pictures but they didnt cme out too well. tbottom od the spindle has a polished area where the inner bearing would sit. the face the place where the seal rides is also scored somewhat. on the spindle where the out bearing sits, it has a polished look on the drivers side, and what looks to be scoring on the passenger side.
its hard to get a good picture since it reflect the light so well and it blows out the contrast
