Page 1 of 3 1 2 3
Are there any members here that sell ROL gaskets? #647168
03/21/10 07:08 PM
03/21/10 07:08 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I wrote down ROL's 1-800 number so I can call them tomorrow but I was just thinking maybe I could help support a Moparts member. I need part #HG31130HT head gaskets.
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647169
03/21/10 07:10 PM
03/21/10 07:10 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
I mabye wrong,but didn't NAPA carry Rol? I have some Rol water pump gaskets that I got from NAPA..
Re: Are there any members here that sell ROL gaskets? [Re: Hemiruss] #647170
03/21/10 10:59 PM
03/21/10 10:59 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
I believe O'reily(sp) sells Rol products and I have ordered them through here before ROL
Price has gone up though. I used to get them for about $40.00 a pair!
Re: Are there any members here that sell ROL gaskets? [Re: cl440] #647171
03/21/10 11:04 PM
03/21/10 11:04 PM
IN
ahy Offline
ahy  Offline
IN
MOPARTS sponsor 440 Source sells ROL gaskets.
Re: Are there any members here that sell ROL gaskets? [Re: ahy] #647172
03/22/10 01:29 AM
03/22/10 01:29 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647173
03/22/10 10:10 AM
03/22/10 10:10 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Autozone sells them
Rich H.
Esse Quam Videri
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647174
03/22/10 11:56 AM
03/22/10 11:56 AM
Locomotion Offline
Locomotion  Offline
I'm not totally clear on the situation, but those ROL HT gaskets may be getting phased out and replaced with what use to be Corteco with the white coating.
The (ex?)Corteco are suppose to be good gaskets, but I haven't gotten all the info yet. They are thinner @ .038" compared to ROL .045".
Re: Are there any members here that sell ROL gaskets? [Re: Locomotion] #647175
03/22/10 06:57 PM
03/22/10 06:57 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Hmmm, I'd like to hear more about these. Do you have a price and part number for the Corteco?
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647176
03/22/10 07:08 PM
03/22/10 07:08 PM
Locomotion Offline
Locomotion  Offline
This is all I know about them. I have one but don't know if it is made with an integral stainless ring like some others, or if it really doesn't need it.
web page
web page
web page
Re: Are there any members here that sell ROL gaskets? [Re: Locomotion] #647177
03/23/10 06:53 PM
03/23/10 06:53 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I talked to Brandon today at 440Source and he said the ROL gasket was discontinued about a year ago.
I think I'd like to get something with the stainless ring around the cylinder.
Any other ideas? 4.380 bore. No Cometics, my surfaces aren't smooth and they're out of my price range.
Looks like the Corteco would be part #55655HG, who sells these?
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647178
03/23/10 07:04 PM
03/23/10 07:04 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Mopar Performance P4349559
Head Gaskets, Composition Type, 4.380 in. Bore, .040 in. Compressed Thickness, Chrysler, Big Block, B/RB, Pair
Fire Ring??
Mopar Performance P4529455
Gaskets Head Composite "B/RB" Up To 4.42" Bore .038" Thick
Fire Ring??
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647179
03/23/10 07:37 PM
03/23/10 07:37 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
To make a long story short, Corteco was obviously bought out by ROL. ROL had some cash flow problems, and sold out to another Mexican company, who will apparently and eventually produce the Corteco type gaskets out of Mexico. How long this will take, who knows. You may get some White Seal gaskets, or you may not. They still have mixed inventories between Dallas and Florida warehouses, as well as in Canada.So ROL wasnt really discontinued per say, but many many changes have happened. They do have some gaskets, just not sure WHICH ones. The part number you are quoting is a ROL #. The numbers havent changed from the old ROL numberinmg system.
All that said, how much compression you running? You might want to use the marine Fel Pros. They still have a 300 series stainless fire ring material with a stainless core material sandwiched in the gaslet, but they do not have a wire ring in the combustion area under the core ring. That wont be a big issue unless you have high compression.
RIP Monte Smith
Re: Are there any members here that sell ROL gaskets? [Re: CompWedgeEngines] #647180
03/23/10 07:55 PM
03/23/10 07:55 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I'm about 11.8 to 1.
What's the part number for the Marine gasket?
Re: Are there any members here that sell ROL gaskets? [Re: CompWedgeEngines] #647181
03/23/10 08:00 PM
03/23/10 08:00 PM
Locomotion Offline
Locomotion  Offline
Do you know or heard how the performance Corteco gaskets are constructed? Any combustion rings/reinforcements or compression limits?
Re: Are there any members here that sell ROL gaskets? [Re: Locomotion] #647182
03/24/10 07:38 PM
03/24/10 07:38 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I tried calling Corteco for info today but was too late, I'll try earlier tomorrow if I have time at work.
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647183
03/24/10 07:53 PM
03/24/10 07:53 PM
Locomotion Offline
Locomotion  Offline
I called Corteco several weeks ago and I believe they told me to call ROL! I emailed my contact there but haven't heard back yet. But it would make sense to call ROL if Corteco sold them their automotive gasket division - or however that that went. I'll need to call too.
Re: Are there any members here that sell ROL gaskets? [Re: Locomotion] #647184
03/27/10 03:04 PM
03/27/10 03:04 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Talk about a run-around. I called Corteco and finally someone answered but he seemed kinda clueless on where to order them from, he gave me a customer service number, 1-800-327-1027, but nobody has answered yet.
Is that Jegs gasket listed above the same as the ROL gasket that I listed in my original post?
I called Autozone, Advance, etc. and nobody like that carries the ROL gaskets.
What about the Mopar Performance gaskets I listed above, any good? I know I used one of those on my 451 with no problems.
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647185
03/27/10 11:37 PM
03/27/10 11:37 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I think I'm just gonna go with this gasket:
Gaskets Head Composite "B/RB" Up To 4.42" Bore .038" Thick, and has the stainless fire ring.
$73.95 for the pair.
But Summit is showing out of stock on them and Jegs doesn't show them at all on their website, so now I gotta hunt these down.
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647186
03/27/10 11:48 PM
03/27/10 11:48 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
like i said before..the jegs ones I bought for small block were the ROL head gaskets..
looking at the BB ones they appear to be the same unless they have changed them out.
http://www.jegs.com/i/JEGS/555/210540/10002/-1?parentProductId=937090
Tony
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647187
03/28/10 09:17 AM
03/28/10 09:17 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
prosport, you may want to try SCE. they also make a compsite gasket. i bought their last ones for small block as there being phased out also, but they may have some left for big block. worth a try.
Page 1 of 3 1 2 3
