Small block e-curve distributor #647130
03/21/10 06:11 PM
03/21/10 06:11 PM
AndyF Offline OP
AndyF  Offline OP
I just finished up some dyno tests using the MSD e-curve distributor. Nice unit with a lot of features. It has 100 advance curves built in. The curves are selected with a couple of rotary switches on the circuit board. There is also a built in rev limiter. This distributor has a port for vacuum advance but the vacuum is converted to a digital signal rather than pulling on a lever arm.
Re: Small block e-curve distributor [Re: AndyF] #647131
03/21/10 07:07 PM
03/21/10 07:07 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
I have one on my 410 dakota..
Re: Small block e-curve distributor [Re: AndyF] #647132
03/21/10 09:16 PM
03/21/10 09:16 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Ya gotta love modern electronic technology Now just put a port injected EFI system on it with a tunable fuel curve...
Is this research for another awesome informative book on small blocks this time
Gus
64 Plymouth Savoy
Dana 60
Re: Small block e-curve distributor [Re: fourgearsavoy] #647133
05/30/10 12:22 PM
05/30/10 12:22 PM
oklahoma
flash1 Offline
flash1  Offline
oklahoma
I have an E-Curve on my project car also, it's awesome. Sure beats changing springs and things.
Curve Track - www.cammhsm.com E-Curve curve tracking system
