Re: Drop in fuel pressure help!
[Re: ireland383]
#647104
03/21/10 07:04 PM
03/21/10 07:04 PM
Posts: 1,629 wilmington,ohio
ohiodemon
wilmington,ohio
mechanical or electric pump ? do you use an adjustable regulator ? are you running a return line from the pump ?
[Re: MNobody]
#647107
03/21/10 09:54 PM
03/21/10 09:54 PM
RapidRobert
(1) The gauge itself (2) the sock or the line rearward from the pump (hookup a gas can to pump inlet to confimn/eliminate both)
[Re: Dodgem]
#647109
03/21/10 10:00 PM
03/21/10 10:00 PM
Posts: 5,270 Missouri
MY340
Missouri
Check the small section of connecting hose back by the gas tank. If it's in bad shape you could be sucking air into the fuel line.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: ireland383]
#647111
03/21/10 11:49 PM
03/21/10 11:49 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Is it a liquid filled?? If it is liquid filed they are real sensitive to heat changes under the hood. as the temp goes up they read lower and lower even though the fuel pressure actually stays the same.
[Re: Dodgem]
#647112
03/22/10 12:20 AM
03/22/10 12:20 AM
Posts: 520 New Zealand
nz383man
New Zealand
I posted this a couple of weeks ago, I hope it helps!
Last night I missed out racing at the only 1/4 mile event for the year that is within 1 hour of my house! I hope after reading this it will not happen to any of you.
My car was surging at full revs but the trans was playing up as well so I took monday & tuesday off work to sort the trans, got it back together on tuesday arvo & out to the tech inspection at Mosgiel on tuesday night. After that I give it a bit in 2nd going up saddle hill (steep 3 laner) it started to surge although the A/F still looked OK but it did feel like a lean surge. I backed off checked for lights & sirens then back into it again, this time the A/F went to [Edited by Moparts - Family Friendly Site - Keep it clean] so I took it quietly back home.
Suspecting a blockage rather than a fault with my 1 year old pump I changed the filter, blew out the lines, replaced all rubber lines just in case they were bad on the inside, remover the sender unit & removed the filter from in the tank. I fitted a fuel pressure gauge above the hood so I could see what was going on, 6-6.6 psi at idle & low load, 3psi at about 3K & almost 0 at 5K under load. I swapped the fuel pump for the original one that was still working when removed (& tested with good pressure & vacuum on the bench) only to find it was worse, this was 1 hr before the event I was entered in. Next I checked the stroke of the fuel pump pushrod & that of a new comp cam I had to see if the cam had worn, 2% wear at most, not the problem. Then I measured the relative position of the pump pushrod & the arm on the pump & things did not add up. I phoned the Dude running the 1/4 to pull out & he said if I turned up late I was still in. We tried for over an hour to get that poxy little plug out that gives access to the pump pushrod & at 7pm I gave up Today with a bit more time & effort the plug did come out & I got to see that little piece of metal that caused me all this drama. I can't believe how much pushrod is worn, both ends were worn hollow, .018" deep on the cam end & .022" on the pump end. There was major wear on the cam end leaving an effective pushrod length of only 2.874" which is .368" shorter than the MP P529569 pushrod ( 3.242") This is why I had no fuel pressure, the effective stroke was so short I wasn't getting enough volume of fuel to build any pressure.
My advice to anyone with a bigblock -
Any time you are building an engine, changing a cam, changing a fuel pump (mechanical) or have any fuel issues at all take that damn plug out, remove the pump pushrod & check it for wear!
[Re: ireland383]
#647116
03/22/10 07:44 AM
03/22/10 07:44 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
""It is liquid filled."" That might be the problem. As mentioned ealier, the liquid filled gages are affected by the ambient heat in the engine compartment. Try one without liquid to see if it reads the same. I had this same problem with a liquid filled unit. I replaced it with one without liquid and everything was fine.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
