Dash and steering column paint. What's should I use? #647063
03/21/10 05:02 PM
03/21/10 05:02 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Need to repaint the dash frame and steering column in the Demon. Not looking for 100% factory correct but I want it to look right (flatness/texture/etc). What type of paint should I use?
Re: Dash and steering column paint. What's should I use? [Re: VITC_GTX] #647064
03/21/10 05:35 PM
03/21/10 05:35 PM
Texas
carcrazyguy Offline
carcrazyguy  Offline
Texas
Mike Mancini has the correct paint if you decide to go that route.
Re: Dash and steering column paint. What's should I use? [Re: VITC_GTX] #647065
03/21/10 05:50 PM
03/21/10 05:50 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
I need to do around my ignition switch on my 70 RR,keys dangeling down have make alot of small little nics.Would like to know myself.
Re: Dash and steering column paint. What's should I use? [Re: VITC_GTX] #647066
03/22/10 03:59 AM
03/22/10 03:59 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
not sure about correctness, but i used laquer based paint on my dash without getting the paint too wet, and it looks good with a semi-gloss finish. It does not have a "flat" no-gloss finish. If you need the no-gloss finish I think you need to add something to the paint?
Re: Dash and steering column paint. What's should I use? [Re: 451Mopar] #647067
03/22/10 09:05 AM
03/22/10 09:05 AM
Flint, MI
Gusteve Offline
I Love the Unicorn Song!!
Gusteve  Offline
Flint, MI
If you want to go cheap - Krylon Black Semi-Flat. Looks darn close to factory, IMHO.
Re: Dash and steering column paint. What's should I use? [Re: Gusteve] #647068
03/22/10 12:12 PM
03/22/10 12:12 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I thought of this but I was looking for something one step better. I would hate to have this stuff start peeling, chipping, etc once it's installed.
Does SEM or someone make something for this?
Re: Dash and steering column paint. What's should I use? [Re: VITC_GTX] #647069
03/22/10 02:26 PM
03/22/10 02:26 PM
central IL reg Nov 18, 1999
Stroker Offline
Stroker  Offline
I used Krylon semi-flat in my Charger, and it's held up fine since the early '80s.
Re: Dash and steering column paint. What's should I use? [Re: Stroker] #647070
03/22/10 08:37 PM
03/22/10 08:37 PM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
If stripped to bare metal, would a primer be required (or advisable)?
Re: Dash and steering column paint. What's should I use? [Re: charger440sixpak] #647071
03/22/10 09:50 PM
03/22/10 09:50 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
My painter buddy helped me with mine.Shot it out of a gun,but he added a flattening agent to dull it down.Was experimented,but I think it ended up with 30% mixture?
Re: Dash and steering column paint. What's should I use? [Re: moretoys] #647072
03/22/10 10:31 PM
03/22/10 10:31 PM
IN
ahy Offline
ahy  Offline
IN
Rustoleum black auto primer and semi flat black Kyrolon on mine - after I cleaned all the armour all applied by the previous owner and sanded. Both good products that hold up well. Factory correct? - not sure. Some models used a textured paint but the Kyrlon looks fine.
Re: Dash and steering column paint. What's should I use? [Re: VITC_GTX] #647073
03/23/10 10:10 AM
03/23/10 10:10 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
What is the paint code in the FSM for the dash and column?
Re: Dash and steering column paint. What's should I use? [Re: Challenger 1] #647074
03/23/10 03:00 PM
03/23/10 03:00 PM
Saline, MI
E
efisixpack Offline
efisixpack  Offline
E
Saline, MI
DDL 9324. I just had some mixed at my local Painers Supply for a 70 challenger dash and column. It's lacquer paint and the texture they use in my opinion is much greater than the original. Almost feels like sand was in the paint. I'm not really happy with it but I've been wanting to try the forumla for a while to see how it looks. Oh, it was also $100 per quart too. I would look into another formula, I really don't think you will be overly excited if using the original one. Just my .02
When I die I want to go like my Grandfather did, quietly in his sleep. Not screaming like the passengers in his car.
Re: Dash and steering column paint. What's should I use? [Re: VITC_GTX] #647075
03/23/10 03:37 PM
03/23/10 03:37 PM
Vermont
440vitamincx Offline
Vermont
Have identical gtx. mine 4bbl. 4-speed
Re: Dash and steering column paint. What's should I use? [Re: VITC_GTX] #647076
03/23/10 04:53 PM
03/23/10 04:53 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I guess it would depend on color...For black I used satin black Rustolium...the semi-gloss is a tad shiney.
Coming soon!!!!
Re: Dash and steering column paint. What's should I use? [Re: efisixpack] #647077
03/23/10 05:14 PM
03/23/10 05:14 PM
Cincinnati, Ohio
Cincinnati, Ohio
I hear you, it sounds like this paint,9346 different numbers but had the same type of finish. I used it on a shaker. And I have used it on dash frames,but I like 9388 a whole lot more.
I love this paint DIA9388 it's the interior black for a 71 challenger. It has no texture and matches exact other OEM dash frames I have laying around. I'm pretty sure everyone would be happy with this black for interiors. It has that look that you can't get out of a spray can.
This is the 9346 paint. It's dusty too.
Re: Dash and steering column paint. What's should I use? [Re: Challenger 1] #647078
03/24/10 04:42 PM
03/24/10 04:42 PM
Saline, MI
E
efisixpack Offline
efisixpack  Offline
E
Saline, MI
Thanks for your input Challenger1. I will have to try the DIA9288 on my demon dash next time. I will not be using the DDL 9324 again, that's for sure.
Re: Dash and steering column paint. What's should I use? [Re: efisixpack] #647079
03/24/10 05:45 PM
03/24/10 05:45 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Plasti Kote's Classic black lacquer is very close to the factory finish.
Nautilus Racing-
