Re: Dash and steering column paint. What's should I use?
[Re: Gusteve]
#647068
03/22/10 12:12 PM
03/22/10 12:12 PM
Posts: 4,929 Tri-Cities, Washington
VITC_GTX
If you want to go cheap - Krylon Black Semi-Flat. Looks darn close to factory, IMHO.
I thought of this but I was looking for something one step better. I would hate to have this stuff start peeling, chipping, etc once it's installed.
Does SEM or someone make something for this?
[Re: efisixpack]
#647077
03/23/10 05:14 PM
03/23/10 05:14 PM
Challenger 1
Cincinnati, Ohio
What is the paint code in the FSM for the dash and column?
DDL 9324. I just had some mixed at my local Painers Supply for a 70 challenger dash and column. It's lacquer paint and the texture they use in my opinion is much greater than the original. Almost feels like sand was in the paint. I'm not really happy with it but I've been wanting to try the forumla for a while to see how it looks. Oh, it was also $100 per quart too. I would look into another formula, I really don't think you will be overly excited if using the original one. Just my .02
I hear you, it sounds like this paint,9346 different numbers but had the same type of finish. I used it on a shaker. And I have used it on dash frames,but I like 9388 a whole lot more. I love this paint DIA9388 it's the interior black for a 71 challenger. It has no texture and matches exact other OEM dash frames I have laying around. I'm pretty sure everyone would be happy with this black for interiors. It has that look that you can't get out of a spray can. This is the 9346 paint. It's dusty too.
[Re: Challenger 1]
#647078
03/24/10 04:42 PM
03/24/10 04:42 PM
Posts: 1,240 Saline, MI
efisixpack
Saline, MI
Thanks for your input Challenger1. I will have to try the DIA9288 on my demon dash next time. I will not be using the DDL 9324 again, that's for sure.
When I die I want to go like my Grandfather did, quietly in his sleep. Not screaming like the passengers in his car.
[Re: efisixpack]
#647079
03/24/10 05:45 PM
03/24/10 05:45 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Plasti Kote's Classic black lacquer is very close to the factory finish.
