Re: e-body speaker fader switch placement?
[Re: burdar]
#647047
03/22/10 11:19 AM
03/22/10 11:19 AM
Posts: 4,165 Florida
cataclysm80
Rallye dash speaker fader is by the heater controls. Non-Rallye dash speaker fader is on the instrument cluster bezel as shown in the pic. Which are you looking for? Need measurements? Tav
[Re: cataclysm80]
#647051
03/23/10 02:07 AM
03/23/10 02:07 AM
Posts: 8,850 Central Coast, Calif.
Snoopy
Rallye measurements... measurements are to center of hole. (shadows make pic look funny) Click on attachment to view larger image.
Tav
The measurements are not correct. If I can find my panel, I will try to post a picture.
[Re: Snoopy]
#647052
03/23/10 11:32 AM
03/23/10 11:32 AM
cataclysm80
Tav
That's interesting... I still have the panel, and measured it myself. I'll try to double check it.
You'll notice from the pic that it's a panel for a rallye dash with AC controls, not quite the same as the rallye dash with heater only panel you posted. I wouldn't think that the fader would be located differently on AC vs. Heater only. Any help appreciated. Thanks for checking into this Snoopy!
Tav
[Re: Snoopy]
#647055
03/24/10 06:30 PM
03/24/10 06:30 PM
cataclysm80
hmmm Well, I checked the measurements on that panel I have. They are as I posted, no typo. I see what you're saying though Snoopy. I got this panel used with a fader switch installed on it. It's possible that someone drilled it. What locates in the 2 little holes? I'm guessing it's the bezel with the "rear speaker" wording on it. I still have the fader switch that came on this panel around here somewhere, but couldn't find it with a quick glance. It will take more digging. When I hold this panel up against my dash frame, this fader hole does line up with the big round hole in the dash frame for the fader, but until I find the switch and actually screw the panel to the dash frame, it is hard to tell if the panel hole is centered over the dash frame hole. Should the fader switch be centered within that hole in the dash frame? It looks like the circular depression on the back side of the panel (visible in my pic above) is the same size as the hole in the dash frame. Surely the switch doesn't belong centered in that depression, because that would move the switch up quite a bit. All pics I've seen so far look like the fader switch is centered top to bottom on the panel. If anyone out there has one of these panels they can post measurements from, that would be very helpful. I may have to fill this panel and drill a new hole before repainting it. Tav
[Re: cataclysm80]
#647058
03/24/10 08:29 PM
03/24/10 08:29 PM
Snoopy
The blue arrows point to the tabs that are used to locate the fader and bezel on the panel using the two smaller holes in the panel.
Bezel at 12 o'clock. Fader at 3 o'clock.
