4130 sreering shaft question #646796
03/21/10 10:38 AM
03/21/10 10:38 AM
Way North Illinois
JandJ_Racing Offline OP
Way North Illinois
How thick should a 3/4" 4130 (is that the one to use) tube be for use as a steering shaft??? .095 about right?
Re: 4130 sreering shaft question [Re: JandJ_Racing] #646797
03/21/10 12:07 PM
03/21/10 12:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use 3/4 x .065
Re: 4130 sreering shaft question [Re: MR_P_BODY] #646798
03/21/10 12:43 PM
03/21/10 12:43 PM
Way North Illinois
Way North Illinois
I use 3/4 x .065
Any particular reason? Thank you
Re: 4130 sreering shaft question [Re: JandJ_Racing] #646799
03/21/10 12:52 PM
03/21/10 12:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
2 factors.... first is where I brace the column and
I felt it was plenty strong enough.... I triangulate
the column with 2 tubes about 3" from where the quick
connect is
