Re: Brake caliper noise
[Re: shadango]
#646563
03/20/10 10:54 PM
03/20/10 10:54 PM
RapidRobert
no need for the rubber bands. you need to bend those thin metal retainers (2) on each wheel that hold the caliper to the horseshoe adapter. Bend the part on the inside that bears down on the calipers itself and while you are there might real quick wire brush the "ways", the V grooves then use antisieze or dry lube or leave em dry your preference. This is not related to your problem but might be helpful and would take seconds to do. EDIT meant to say the part that bears down on the pads themselves
[Re: buildanother]
#646566
03/21/10 08:53 AM
03/21/10 08:53 AM
Posts: 32 pittsburgh, pa
shadango
pittsburgh, pa
Never needed the bands here either. Are you certain you have matching components, installed correctly?
The componants should match..... 78/79 Cordoba "large disk' brackets and 80 NYer calipers....Both cars seem to use the same calipers when I look them up on autozone or rock auto's sites.
I plan on trying to prebend the plates a little more and see if that helps, but I have the rubber bands and would really like to install them to see if they do anything...just cantfigure out how they are installed.
[Re: RapidRobert]
#646568
03/21/10 09:08 AM
03/21/10 09:08 AM
shadango
pittsburgh, pa
So all i need to do is bend them more? it seems like such a strange setup as far as the metal plate holding them in .....seemed like there should be "more" holding them on.... everyone seems to think they arent needed though as you suggested.
(1) No if they are lightly snug now (2) Agreed it seems inadequate but it does work well but as Buildanother said there is something else going on. I've never used the rubber bands and not ever sure what they are for as they would not last but they for sure are not related to your problem. Oh I got an idea, the 1 pad w the ears/tabs you need to bend each of the tabs slightly so you have to force this pad on w a bit of force for it to snap in place and the other pad needs to float slightly when you drop it in place.
Wouldnt bending the pad ears really only affect the movement of the pads in the caliper?
My issue is that the caliper is moving on the adaptor in ways it shouldnt and making the noise.....
I will be taking a look at it this morning to try again......I know the plates must have lost some of their tension...but the question is why. ???
