Hi folks...
I recently did a drum to disk conversion on my 72 Barracuda. My setup is a set of calipers/rotors from a 80 NYer and the "large" caliper mounting brackets.
I found that the slider calipers are making lots of noise when I hit bumps.
The calipers are actually loose enough on the mounts to move a bit when the brake is not depressed and the resulting noise is LOUD...resonates thru the whole front end.
Step on the brakes a little and the noise disappears.
I am starting to wonder if the little black rubber bands that came in the hardware kit and didn't use (I waas told they werent needed) are what would prevent this?
Any thoughts on this?
Thanks folks
