Tested different front shocks today #646514
03/20/10 09:54 PM
03/20/10 09:54 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
This was my first day at the track this season. It was a beautiful day and I had some fun and it is always good to run the car again.
From this post about ideas for improvement:
What would you change in my combo?
One of the ideas was to use different front shocks to better control the front end "bounce" after the wheel stand. I had been running Koni SPA-1 shocks, and I borrowed a set of the single adjustable QA1 shocks to try. Part number TC1538P for '62-'76 Darts, Dusters, etc. They have 12 click settings. After doing a compression/rebound by hand comparison to the setting that was working with my Koni's, I started the day 2 clicks from softest; ie 12 positions and this was 3.
The car was running great, even though the air was not "great" for this time of year. The good thing was the air didn't change much at all for most of the day. I made 7 passes (including the gambler's race) this was about it for all but maybe the 1st one at 11am. 77ºF, 23% RH (dry), 29.96"Hg; or about 1200 ft Density Altitude. The time slips were very consistant at:
1.24 sixty foot
9.25 ET
141 mph
The results of changing the shock settings. At "3", the car acted very close to my Koni's. Good launch and sixty foot, and about 2 front end up/down after the wheel stand. I did 3 runs this way, then increased the damping to "4". Well, that was too much extension damping and the car started to spin the tires (not enough weight transfer at the hit). I went back to a setting of "3" and it was normal again.
So, these shocks are not going to help. Thanks to Micheal Johnson for letting me borrow them for the test.
In the gambler's race, I did have a good time beating a full electronics dragster with my footbrake backhalf door car. I cut a 0.005 light, and ran dead-on with an 8 (9.258) touching the brakes to take 0.02 stripe at the finish line. From the 1000 ft time, I calculated it would have run dead-on with a 1 (9.251) That was my most enjoyable run of the day.
The car ran a little faster than I expected (ET) for the weather. But the very dry air tends to do that. Also, I was running open headers; no collector extensions (4") with turnouts, and no 4" bullet mufflers with turnouts either. That is what I ran all last year. On the 3rd pass, I richened the E85 slightly and it went 0.02 quicker; so I stayed with that tune the rest of the day.
Re: Tested different front shocks today [Re: 440Jim] #646515
03/20/10 10:04 PM
03/20/10 10:04 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
jim, from what i have seen, some cars just have to have the front end "moving" to work.
Re: Tested different front shocks today [Re: tjmarcus1] #646516
03/20/10 10:13 PM
03/20/10 10:13 PM
gregsdart Offline
gregsdart  Offline
Welcome to the world of double adjustable shocks. Mine are set very stiff for landing, pretty soft for going up.
Re: Tested different front shocks today [Re: gregsdart] #646517
03/20/10 10:18 PM
03/20/10 10:18 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Yea Greg, that might show improvement. At the settings I ran, and comparing by hand (not the best way), these have noticably more compression damping at similar extension damping. So I had some hope. I think this chassis (front heavy), needs the loose extension and that doesn't allow the quickest settling after the wheel stand.
The car works good, just trying to find something. I have the wheel stand somewhat under control with travel limiting in the front, etc. But it still takes a few pogos to completely settle out. If the wheel stand gets out of hand, it bounces pretty bad.
Glad I didn't pay $300 for a pair of shocks that don't help (but still work fine like my Koni's).
Re: Tested different front shocks today [Re: 440Jim] #646518
03/20/10 10:27 PM
03/20/10 10:27 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
What are you running for rear shocks?.
Your race results are a good read....I love how your car is so consistent.
Re: Tested different front shocks today [Re: toddd] #646519
03/20/10 10:32 PM
03/20/10 10:32 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
When I was in the staging lanes and saw I was going to run the dragster, I said to my buddy, "I am going to run dead on this dial-in". And I knew I needed to cut the tree down hard against a delay box car. I love this car. It isn't perfect, but I have it working pretty consistant.
The rear is a ladder bar suspension (coil overs) with AVO single adjustable shocks, 130 lb springs. That is what came with the car when I bought it in the fall of 2001 as a rolling chassis.
And when I changed the damping on the QA1's from 3 to 4, the spin wasn't real bad. The sixty went from 1.24 to 1.27 and I felt the tires grip/release/grip/release/grip and the front didn't get the wheels off the ground much (maybe an inch, maybe nothing). The car is very nose heavy (weight distribution).
Re: Tested different front shocks today [Re: 440Jim] #646520
03/20/10 10:36 PM
03/20/10 10:36 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... it still takes a few pogos to completely settle out.
And that is exactly why I suggested trying something w/ really stiff compression damping, thinking it could help that problem. I don't think you had the right shocks for a true "proof of concept" test. However, short of me ponying up the $$$ for a set of the "right" shocks just to satisfy my own curiosity about how they'd work on your car, today's test will have to do...
Re: Tested different front shocks today [Re: BradH] #646521
03/20/10 10:40 PM
03/20/10 10:40 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Brad and Greg are thinking the same.
Anyway, I was very happy at the ET the car ran at 77 degrees. I will have to find a day to test the open headers, collector extensions, and bullet mufflers.
Brad, I got 7 passes in today! For an MIR test and tune with gambler's race, that is a lot. Not as big a turn out as I expected for such a nice sunny day.
Re: Tested different front shocks today [Re: 440Jim] #646522
03/20/10 11:33 PM
03/20/10 11:33 PM
SoCal
Brian Hafliger Offline
SoCal
I like testing things too, but if your looking for a sizable gain...I still stand by my first post..."I would go with an 8" trans brake converter from A1, a nice solid roller cam with around .750 lift, rub the heads a little bit more to work with new combo, and go with 1.7 TD rockers.
Then do a brake and 2 step...fun fun!!"
I know it's not cheap, but IMO you would see very good gains by doing most if not all of these things based on your info.
You could also keep testing things...I found alot in my chassis with a little here and a little there.
At least your racing...
Brian Hafliger
Re: Tested different front shocks today [Re: Brian Hafliger] #646523
03/20/10 11:49 PM
03/20/10 11:49 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Good post and info Jim. I'm running those shocks all around on my Dart. I'm not near as fast as you. But your results did let me know I'm in the ball park with my front shock setting. Jim
Re: Tested different front shocks today [Re: rt66jim] #646524
03/21/10 08:08 AM
03/21/10 08:08 AM
tboomer Offline
tboomer  Offline
Great post,Jim!! The way the car and driver is working....Is it really worth changing a bunch of things? That car runs dead on and is a proven winner!! I wouldn't even put a tranny brake in it..You are a very good footbraker....Congrats on trailering a pipe rack...That isn't easy to do!!
Re: Tested different front shocks today [Re: 440Jim] #646525
03/21/10 09:58 AM
03/21/10 09:58 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Good to see you racing. Car/driver on as usual As soon as I saw you were trying TC1538P, I knew they wouldn't work for your car. They are really good shocks for non wheelstanding cars. You need to try an R valving QA1, the new 6855M Afco, or the double adjustable route like Greg mentioned.
Fun read, thanks
Re: Tested different front shocks today [Re: Leigh] #646526
03/21/10 10:53 AM
03/21/10 10:53 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
GREAT car & driver! I'll take some of that 77* weather,Jim! Randy
Re: Tested different front shocks today [Re: Brian Hafliger] #646527
03/21/10 02:47 PM
03/21/10 02:47 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
the only thing i would say is IF you go a t-brake the car will probably want to cut a flip backwards. some cars will be a lot quicker on the t-brake, some will be slower. with the awesome torque have and the ladder bar set up it will be hard to tune it out. and if you have to "tune it out" then what's the point?
Re: Tested different front shocks today [Re: tjmarcus1] #646528
03/21/10 03:54 PM
03/21/10 03:54 PM
SoCal
SoCal
Most cars pick up with a brake and 2 step and are easier to race with.
Just my that may be worth less...
Brian Hafliger
Re: Tested different front shocks today [Re: Brian Hafliger] #646529
03/21/10 04:00 PM
03/21/10 04:00 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
yep brian, i hear what you are saying, but jims car is rather violent on the footbrake. the t-brake will be more so. i know from experience, the more violent, the harder it is to run the numbers.
Re: Tested different front shocks today [Re: Brian Hafliger] #646530
03/21/10 04:39 PM
03/21/10 04:39 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
The brake is illegal in the class I run. This is footbrake country, not no-box. So that change is not an option.
